I think he's referring to the really serious folks that are pumpin out rwhp in the neighborhood of 700.
Alright, I can wrap my head around that. Unless he wants to go custom set up with a TVS series blower, his only option for a Positive Displacement set up is pretty much one of the Kenne Bell or
Whipple kits, but if that's the case, he probably should have specified that in his answer. It might have saved me a whole lot of the typing I did below....
So, like a little more than 100hp over stock. No thanks. Roots blowers generate a ton of heat, and take a lot of power to turn. The only reason that car comes with a roots blower is that it is easy to warranty.
Kurt
100hp over stock? How do you figure? The N/A version of the '03 Cobra engine is basically a cookie cutter design of the Mach 1 mill (save for the Mach's higher compression ratio) and they're putting down about 270rwhp. Last time I checked, 500hp minus 270hp was 230....not 100. And making anywhere from an additional200-230rwhp for about $2,000-2,500 in modifications certainly seems worth it as far as I'm concerned.
....as far as Roots blower generating a ton of heat. You do realize the most efficient and pound for pound, most powerful positive displacement design built to date (The Eaton TVS) utilizes a hybrid-Roots design, right?
You wanna see heat, try running a Twin Screw without an intercooler. You'd be surprised to learn that it’s pumping out even higher discharge temperatures than the Eaton down low and is only slightly more efficient than a 4th Gen on the top end. This Cobra’s MP112 isn’t the same 2nd or 3rd Gen design found in the old Supercoupe Thunderbird and certainly not the same old strait cut, top fed set up seen with the old 6-71 or 8-71 Roots design. The 4th Gen MP112 is capable of hanging with a comparable twin screw nearly all the way to red line and even boasts better adiabatic efficiency in the lower ranges. The only reason you'll notice the Twin Screw blowers coming out on top all the time during these so called "unbiased comparisons" (always performed by Kenne Bell if you'll notice) is because of the sheer displacement differences between the two blowers. What's the Cobra's replacement for the MP112....a 2.6L or 2.8L? So the massive Twin Screw out powers the all of 1.84L that the M112 is and it’s got to be based solely on the inefficient design of the Eaton, right? Think again man. 2.6L is nearly a 160ci blower and the 2.8L is just over 170ci.
So is any surprise that either of the larger Twin Screws is capable of moving a larger volume of air, while turning slower speeds (therefore resulting in a cooler ACT) than the stock Eaton?
I mean, if you want to compare apples to apples, how about a little closer match up? Why not pit the stock Cobra blower to the likes of the 2.1L Twin Screw? I'll tell you why, because the 2.1L barely out powers the smaller 4th Gen MP112 (and even then only in the upper ranges) and its victory doesn’t look nearly as impressive on paper.....that’s why. I mean, why would anyone lay out $3,000 worth of cabbage to swap out their Eaton to a 2.1L when its barely able to squeak past the stock Eaton’s numbers? Why not spend $1,000 less and upgrade to a 5th Generation Magnum Powers MP112 if more power is what you’re after. It’s already proven itself capable of walking away from the 2.1L and it’s a less expensive unit to boot. And the only major change between the 4th Gen MP114 and Magnum Powers unit is improvements to the inlet and outlet design. Displacement itself remains unchanged.
Look man, I’m not saying you have to like one set up over another, but you’re dead wrong if you think it’s the design of the blower itself that’s holding the Eaton back, or propelling the Kenne Bell forward.
Get them on an even playing field and you’ll see that you’re spending an awful lot of money just for a Kenne Bell name plate on your intake manifold.
