Exactly...
You want 94-95 spindles only.
They are wider track than Fox, but only very slightly.
After that, they only get wider and wider.
The 94-95 brakes are iron calipers with single pistons.
Then there are the PBRs, which are aluminum calipers with dual pistons.
Those are the ones you want if you have 16"-17" rims.
The Cobras are tight in the 17" rims that will take them, and don't fit at all in some 17" rims.
Whatever brakes you get, make sure you get the brackets too, they all have their own brackets that don't interchange, but will bolt to any SN95 spindle. Brake lines are also different between them at the calipers, but the body connections are the same, and I believe they will connect to a later Fox.
You will need a larger displacement master too.
Either the 94-95 GT or 94-95 Cobra master will work fine, but they recommend the Cobra for best results.
The Cobra has a slightly smaller bore, but they say it is better.
