Well, you'll need the panels and the stainless trim, the pull cup, the pull bracket, the cup insert, and new door handle pivots. Change the pivots, install the moisture shields, install the pull brackets, Put the stalnless trim and deluxe clips on the back, install the panel, install the pull cup, install the pull cup insert, install the door handle escutucheon, door handle escutucheon washer, door handle, window crank washer, window crank, then step back and admire your work.
