7.5 Rear end question?
I would like to keep my 7.5 rear end in my car and not convert to an 8.8 rear end what is the cheapest way to make it posi. I would also like to add 373 gears or 355 gears, approximately pushing 300HP with new build what gears should I go with?
All the mustang 5.0s from 86 to 93 have limited slip posi traction 4 lug 8.8 rears. The clutch packs aren't hard to rebuild. They wear out causing a bunch of cats to one wheel peel.
An old school method of helping the clutch packs last is to change the oil every 40-50 thousand miles and then drive in a tight figure eight slowly for 5 or 6 rounds, kinda cleans the clutch faces.
  • Useful
Reactions: 1 user
Also, 7.5 in 1982 through 1985 Capris and Mustang are already Traction-Lok from the factory (they are not "posi" so please stop calling it that) so there is no need to "convert" to T-L. And 3.55 is a 8.8" gear. It is not available for 7.5. The close equivalent for a 7.5 is 3.45.
Reactions: 1 user
When the 8.8 was new in Mustangs and available in the Ford Performance catalog, I found it a lot less expensive to put the Eaton style (clutch plate) actual Ford Limited slip in the stock 7.5” rear end.
Now, a salvage 8.8” rear is easier to find that should bolt in. I’d start with a good 8.8” core and go through it with new bearings, seals, and possibly clutches.
You can buy 7.5 in traction locks in Ranger trucks and early foxes and aftermarket. I have a 2.73 stock one in my 79 and a Ford Racing one with a 4.10 gears in my 82. And there are four and five lug axles for them. My 4.10 has been 7.90 in the eighth with 1.80 sixty foots. So far so good. Its a lot lighter than an 8.8. No worries, I have several 8.8s waiting in the wings.
What?.
What??? I’m not the one that has a problem with people using GM terminology for their Ford parts??
Say it ain’t so.
All of the Fox 5.0 Mustangs (except the 93 Cobra and maybe the turbo coupe super edition I am blanking out on) came with 8.8 rear ends and a LSD WITH 4 lug axles. Your wheels will not have to be changed, nor the front end parts. A wiki search will tell you for sure, but it seems like 85 was the first year the GT got the 8.8”.
There are many 8.8 traction lock rears with 4lug axles
Reactions: 1 user
@Rcdgl any idea on HP and torque without me using a drag calculator? How many passes, how much other driving and what transmission are you using with the 7.5”?
I wish my Ranger had come with a LSD rear end.
