AFR and Trickflow Head Information
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Over time, there is many post about what heads come with certain parts so I figured I would get some information together to help us all better understand what comes with certain heads:nice:
If any corrections or additions need to be made, let me know:)
Airflow Research Heads 100% CNC Machined
Assembled Head Part Numbers:
AFR 165 Series:
033-1400 – Street, 165cc Head, 61cc, 1.90”/1.60” Valves, 1.450” Dual Valve Spring w/ dampner (.550”), 10* locks, 3/8” rocker studs, smog provisions. $1,390
033-1402 – Street, 165cc Head, 58cc, 1.90”/1.60” Valves, 1.450” Dual Valve Spring w/ dampner (.550”), 10* locks, 3/8” rocker studs, smog provisions. $1,390
033-1472* - Street, 165cc Head, 60cc, 1.90”/1.60” Valves, 1.450” Dual Valve Springs w/ dampner (.550”), 10* locks, smog provisions. $1,390
.550” lift springs have 120# of spring pressure and 69cc exhaust port.
*Pedestal Mount, not stud-mounted rockers.
Airflow Chart for Street AFR 165 Heads:
Lift Value (in.) - Intake Flow - Exhaust Flow (w/ 1 3/4" pipe)
Inches - CFM - CFM
0.200 - 123 - 118
0.300 - 186 - 153
0.400 - 225 - 178
0.500 - 243 - 185
0.550 - 246 - 190
0.600 - 250 - 191
Tests conducted at 28 in. of water (pressure)
Intake valve size 1.090in./exhaust valve size 1.600 in.
Head Torque – 65-70 ft. lbs with 7/16” stud.
Rocker Stud Torque – 55-60 ft. lbs.
Rocker Pedestal Torque – 25-30 ft. lbs.
Intake Port Gasket – 1.200” x 2.000” w/ 3/8” radius
Exhaust Port Gasket – FEL-1415
Head Gasket – 1962-82 Fel-Pro 375-1011-1 or 1983-93 Fel-Pro 375-1011-2
Head Bolts and Studs – Standard
Spark Plugs – Autolite 3924
Intake/Exhaust Valve Angle - 20*
Angle Mill - .008” per cc
Flat Mill - .006” per cc
For the ultimate small block Ford street car, you've got to use AFR's all new 165cc emissions legal cylinder heads. Unlike some aftermarket heads, AFR's Ford head (CARB EO #250-3) fits all your stock components; no special parts are required! With 1.900 intake valves, 1.600'' exhaust valve, and combustion chamber volumes of 58cc or 6occ, and 69cc exhaust ports, AFR's new 165cc Ford head is perfect for 289 and 302 engines operating from idle to 6000 rpm. A 3/4'' thick head deck makes the AFR head ideal for nitrous or blower applications. Will not accept rail rocker arms. Hardened push rods required with part numbers 1400 and 1402. Note: 1986 5.0L must have piston notched for clearance.
AFR 185 Series:
033-1422 – Street/Track, 185cc Head, 58cc, 2.02”/1.60” Valves, Dual Valve Spring w/ dampner (.550”), 10* locks, 3/8” rocker studs, smog provisions. $1,420.
033-1492* – Street/Track, 185cc Head, 60cc, 2.02”/1.60” Valves, Dual Valve Spring w/ dampner (.550”), 10* locks, smog provisions. $1,420.
Airflow Chart for Street AFR 185 Heads:
Lift Value (in.) - Intake Flow - Exhaust Flow (w 1 3/4" pipe)
Inches - CFM - CFM
0.200 - 129 - 118
0.300 - 189 - 153
0.400 - 234 - 178
0.500 - 267 - 185
0.550 - 273 - 190
0.600 - 277 - 191
Intake valve size 2.020 in./exhaust valve size 1.600 in.
Head Torque – 100 ft. lbs with ½” stud.
Intake Port Gasket – 1.280” x 2.100” w/ 3/8” radius
If you need the world's finest street/strip small block Ford head, check out AFR's all new 185cc intake port emissions legal (CARB EO #250-3) cylinder heads. With 2.020 intake valves, 1.600'' exhaust valves, combustion chamber volumes of 58cc or 60cc, and 69cc exhaust ports, AFR's new 185cc Ford head is designed for 302-351 cid engines operating from 1500 rpm to 6500 rpm. A 3/4'' thick head deck makes the AFR head ideal for nitrous or blower applications. Will not accept rail rocker arms. Hardened pushrods required with heads #1420 and #1422. High flow 2.020 valves might require aftermarket pistons notched for valve clearance. Note: 1986 5.0L must have pistons notched for clearance.
AFR 205 Series:
033-1450 – Track, 205cc Head, 58cc, 2.08”/1.60” Valves, 1.550” Roller Dual Valve Spring w/ dampner (.670”), 10* locks, 7/16” rocker studs, no smog provisions. $1,850.
.670” lift springs have 210# of spring pressure and 70cc exhaust port.
Airflow Chart for Track AFR 205 Heads:
Inches - CFM - CFM
0.200 - 141 - 125
0.300 - 201 - 180
0.400 - 251 - 211
0.500 - 291 - 225
0.550 - 301 - 228
0.600 - 306 - 231
0.700 - 310 - 235
Intake valve size 2.080 in./exhaust valve size 1.600 in.
Exhaust Port Gasket – FEL-1487
Spark Plugs – Autolite 3922
If you're looking for the world's finest street/strip head available, AFR's 205 head is your answer. With 2.080 intake valves, 1.600 exhaust valves this head moves tremendous volumes of air through conservative runner volumes, spelling big torque and horsepower numbers. With combustion chamber volumes of 58cc accompanied by 70cc exhaust parts which are raised .125 higher than stock, AFR's new 205cc is the ultimate choice for 331 through 392 engines operating from 3500 RPM to 8000 RPM. AFR's trademark 3/4'' thick head deck makes them ideal for heavy nitrous or blower applications. With available optional nitrous or blower exhaust ports featuring 75cc, 80cc ultra high flow exhaust ports.
AFR 225 Series:
033-1451 – Track, 225cc Head, 58cc, 2.08”/1.60” Valves, 1.550” Roller Dual Valve Spring w/ dampner (.670”), 10* locks, 7/16” rocker studs, no smog provisions. $2,020.
.670” lift springs have 210# of spring pressure and 80cc exhaust port.
Airflow Chart for Track AFR 225 Heads:
Lift Value (in.) - Intake Flow - Exhaust Flow (with 1 7/8" pipe)
Inches - CFM - CFM
0.200 - 149 - 130
0.300 - 216 - 187
0.400 - 264 - 230
0.500 - 295 - 242
0.600 - 312 - 250
0.700 - 320 - 255
Are you looking for big torque and horsepower number? Only AFR's 225cc will provide you with exactly that. With the largest intake and exhaust runner volumes for our in-line Ford line up, these are the ultimate for NMRA Renegade or Hot Street classes. With 2.080 intake valves and 1.600 exhaust valves these heads move massive amounts of air. Combustion chamber volumes of 58cc accompanied by 80cc exhaust ports which are raised .375 higher than stock. AFR's new 225cc is the perfect choice for 347 through 427 CI windsors engines operating between 4500 to 8500 rpm. The trademark 3/4'' thick head deck makes them ideal for heavy nitrous or blower applications.
Trick Flow Heads
Trickflow H/C/I Combinations:
Street Heat Kits for $2,450:
TFS-K514-350-370 - Street Heat Intake/Street Heat Heads (smog provisions).
TFS-K514-350-370B – Street Heat Intake/Street Heat Heads, Black Upper Intake and Black Valve Covers (smog provisions).
That kit includes:
TFS-51402000 - Stage 1 Cam
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16
TFS-21406700 - Pushrod Set of 16 -6.700”
TFS-51400904 - Head Gasket Set
TFS-51400801 - Cast Valve Covers or TFS-51411801 for Black.
TFS-51400004 - Twisted Wedge/Street Heads, Assembled (Kit has Single Valve Spring)
TFS-51500001 - 5.0L Street Heat EFI Intake Manifold
ARP-154-3601 - ARP Head Bolt Kit
TFS-51400800 - Oil Fill Kit
TFS-51478520 - Billet Timing Chain Set
FEL-TCS45449 - Fel-Pro Timing Cover Gasket Kit
Track Heat Kits for $2,500:
TFS-K514-360-350 – Track Heat Intake/Track Heat Heads (no smog provisions).
TFS-K514-360350B – Track Heat Intake/Track Heat Heads, Black Upper Intake and Black Valve Covers (no smog provisions).
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16, ask for 7/16” stud if wanted.
TFS-51400004 - Twisted Wedge/Street Heads, ask for track heat head upgrade confirmation.
TFS-51500001 - 5.0L Track Heat EFI Intake Manifold
Extra Notes:
The street heat intake has 15 inch runners and the track heat intake has 12 inch runners.
The street heat heads come with smog provisions and the track heat does not. The track heat heads can be ported a bit more because of this.
Both the street heat and track heat heads come with 3/8” rocker studs and the track heat heads can be upgraded to thicker 7/16” rocker studs. Just call your sales representative to get the upgrade.
Both street heat and track heat versions have the option to come with dual valve springs and 10* locks.
Twisted Wedge and Street Heat Heads are the same, not to be confused with Track Heat.
The trickflow h/c/i packages are more designed for the fox-body cars do to valve cover tallness and throttle body adapter plate not being included.
Twisted Wedge/Street Heat Heads:
TFS-51400002 – TW/Street, 170cc Head, 61cc, 1.470" Single Valve Spring (.540”), 7* locks, 3/8” rocker studs, smog provisions, and not machined for o-rings. $1,200.
TFS-51400003 – TW/Street, 170cc Head, 61cc, 1.470" Single Valve Spring (.540”), 7* locks, 3/8” rocker studs, smog provisions and machined for o-rings. $1,310.
TFS-51400004 – TW/Street, 170cc Head, 61cc, 1.460" Dual Valve Springs (.600”), 7* locks, 3/8” rocker studs, smog provisions, and not machined for o-rings. $1,290.
TFS-51400004-C01 – TW/Street, 185cc Head, 64cc, 1.460" Dual Valve Spring (.600”), 7* locks, 3/8” rocker studs, smog provisions, and not machined for o-rings. $1,860.
TFS-51400004-CO2 – TW/Street, 205cc Head, 65cc, Dual Valve Spring (.600”), 7* locks, 3/8” rocker studs, smog provisions, and not machined for o-rings. $1,960.
TFS-51400005 – TW/Street, 170cc Head, 61cc, 1.460" Dual Valve Spring (.600”), 7* locks, 3/8” rocker studs, smog provisions, and machined for o-rings. $1,340.
Track Heat Heads:
TFS-51400010 – Track Heat, 170cc Head, 61cc, 1.460" Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. $1,320.
TFS-51400010-C01 – Ported Track Heat, 185cc Head, 64cc, 1.460" Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. $1,890.
TFS-51400010-C02 – Ported Track Heat, 205cc Head, 65cc, 1.460" Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. $1,990.
TFS-51400011 – Track Heat, 170cc Head, 61cc, 1.460" Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and machined for o-rings. $1,380.
Head Torque – 7/16 in. Head Bolts: Torque to 35. ft.-lbs., 50 ft.-lbs., and 70 ft.-lbs., then tighten only the long bolts an additional 10 ft.-lbs and 1/2 in. Head Bolts: Torque to 35 ft.-lbs., 70 ft.-lbs., and 100 ft.-lbs., then tighten only the long bolts an additional 10 ft.-lbs.
Rocker Stud Torque – 55 ft. lbs.
Intake Port Gasket – 1.200” x 2.000” - FEL-1250
Exhaust Port Gasket – 1.500" x 1.250" - FEL-1415
Head Gasket – TFS-51400904 for engines with non-O-ringed heads, TFS-51400905 for engines with O-ringed heads, Fel-Pro 1022 and 1023 for non O-ringed heads with wider combustion chambers due to porting (1022 is for the left bank, 1023 is for the right bank), Fel-Pro 1006 or TFS-51400901 for all engines with O-ringed heads.
Spark Plugs – Champion RC9YC, AC-FR3LS,NGK-FR5, Autolite-3924, or Accel-416
Intake/Exhaust Valve Angle - 15* Intake/17* Exhaust
Extra Notes:
All valve sizes are 2.02” on the intake and 1.60” on the exhaust and clear stock piston valve relief radials unless noted.
All exhaust runner port volumes are 66cc unless noted.
Intake valve angle is 15* and the exhaust valve angle is 17* unless noted.
The .600” lift dual springs have 135# of seat pressure.
Valve cover head rails are raised .350” from stock, but still fit stock valve covers on '87-93, unless noted.
Twisted Wedge heads (P/N TFS-51400001 and TFS-51400002) are drilled for 7/16" head bolts, but contain a "step" enabling the heads to be easily drilled for 1/2" bolts. The TFS-51400003 heads are drilled for 1/2" bolts.
Racier Trickflow Heads:
TFS-51700001 – 192cc/87cc High Port*, 64cc, Dual Valve Springs (.600”), 7* locks, 3/8” rocker studs, no smog provisions, and not machined for o-rings. $1,370.
TFS-51700002 – 192cc/87cc High Port*, 64cc, Dual Valve Springs (.600”), 7* locks, 3/8” rocker studs, no smog provisions, and machined for o-rings. $1,380.
TFS-52400003-CNC – R-series, 206cc/92cc Head, 2.08/1.60” valves, 61cc, Dual Valve Springs (.680”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. Combustion chamber is CNC’d. $1,810.
TFS-5170T010-C01 – 225cc/95cc High Port**, 2.08/1.60” valves, 58cc, Dual Valve Springs (.700”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. Intake/Exhaust runner and combustion chamber are CNC’d. $2,500.
TFS-5170T012-C01 – 225cc/95cc High Port*, 2.08/1.60” valves, 70cc, Dual Valve Springs (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. Intake/Exhaust runner and combustion chamber are CNC’d. $2,400.
*- Designed for hydraulic roller cams, exhaust port is raised 0.750 in. over stock location, must use headers designed for this cylinder head. Valve cover rail is raised 0.400 in. over stock, 20* intake/exhaust valve angle.
** - Designed for mechanical roller cams. Exhaust port is raised 0.750 in. over stock location; valve cover rail is raised 0.400 in. over stock, 20* intake/exhaust valve angle.
Twisted Wedge/Street Heat Trickflow Footnotes:
They are available bare or fully assembled heads feature 61cc chambers with rotated 2.02 in. intake/1.60 in. exhaust valves moved over the center of the cylinder bores, to build top-end power without sacrificing bottom-end torque. Unlike other 2.02 in. valved heads for small block Fords, the Twisted Wedge heads don't require flycut pistons with most street performance cams. Twisted Wedge heads have stock height intake and exhaust ports for use with most OEM and aftermarket intake and exhaust manifolds. They are available in versions for stud-mounted rocker arms or machined for use with Fel-Pro Loc-Wire head gaskets. Assembled heads come with valves, valve springs, locks, retainers, and head bolt washers.
http://static.summitracing.com/global/images/instructions/tfs-51400002(2)1.pdf
Track Heat Trickflow Footnotes:
Trick Flow's Track Heat heads are ideal for the entry-level Ford bracket racer. The heads have patented 61cc combustion chambers with rotated intake and exhaust valves, 2.02 in. intake/1.60 in. exhaust stainless steel valves, .560 in. thick combustion chamber walls for added strength, and additional support risers in the water jackets. The fully assembled heads feature higher rate valve springs (135 lbs. seat pressure at 1.800 in. installed height), 10 degree locks, and manganese bronze guides. The bare heads feature the valve guides and seats already installed. They're available machined for use with Fel-Pro Loc-Wire head gaskets and are designed for stud mount rocker arms.
http://static.summitracing.com/global/images/instructions/tfs-52400010(2)1.pdf
Airflow Chart for 170cc Street and Track Heat Heads:
Inches - CFM - CFM
0.100 - 063 - 053
0.200 - 141 - 107
0.300 - 205 - 144
0.400 - 233 - 171
0.500 - 251 - 187
0.600 - 251 - 193
Airflow Chart for Ported 185cc Track Heat Heads:
Inches - CFM - CFM
0.100 - 072 - 058
0.200 - 142 - 112
0.300 - 216 - 150
0.400 - 258 - 192
0.500 - 287 - 220
0.600 - 301 - 231
Airflow Chart for CNC Ported 205cc Track Heat Heads:
Part Number: TFS-51400010-C02
Inches - CFM - CFM
0.100 - 071 - 056
0.200 - 144 - 112
0.300 - 220 - 150
0.400 - 270 - 192
0.500 - 299 - 220
0.600 - 316 - 231
Summit owns Trickflow, they are one in the same.
http://www.fordmuscle.com/archives/2003/02/afr/
Edelbrock Heads:
EDL-60379 - Performer, 170cc, 60cc, 1.90"/1.600" Valves, 1.460" Single Valve Springs (.575"), rocker studs not included, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $1,160.
EDL-77189 - Victor Jr., 210cc, 60cc, 2.050"/1.600" Valves, 1.550" Dual Valve Springs (.650"), 7/16" rocker studs, no smog provisions, and not machined for o-rings.
.150" raised valve cover rail, 75cc exhaust port with .130" raised.
Airflow Chart for Performer 1.9 #60379 Heads:
Inches - CFM - CFM
0.100 - 072 - 057
0.200 - 131 - 105
0.300 - 185 - 131
0.400 - 214 - 156
0.500 - 223 - 168
0.600 - 226 - 175
Intake valve size 1.090 in./exhaust valve size 1.600 in.
Airflow Chart for Victor Jr. Heads:
Inches - CFM - CFM
0.100 - 127 - 108
0.200 - 186 - 140
0.300 - 234 - 167
0.400 - 268 - 189
0.500 - 291 - 195
0.600 - 285 - 199
Intake valve size 2.050 in./exhaust valve size 1.600 in.
Holley Heads:
HLY-300-551-2 - Street, 165cc Head, 63cc, 1.90"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, rocker studs not included, smog provisions and not machined for o-rings. $1,380.
HLY-300-575 - Street, 165cc Head, 63cc, 2.02"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, 3/8" rocker studs, smog provisions and not machined for o-rings. $1,690.
17* intake and exhaust valve angle and 71cc exhaust port.
Holley H/C/I Package:
HLY-300-501-1 includes heads, cam, Holley Systemax, double roller timing chain, hardened pushrods, and head bolts. Powerband is 2,000-6,500 RPM. $2,500.
World Product Heads:
WRL-053030-1 - Windsor Jr., Iron, 180cc Head, 58cc, 1.94"/1.60" Valves, 1.250" Single Valve Springs (.560"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $940.
WRL-053030-2 - Windsor Jr., Iron, 180cc Head, 58cc, 1.94"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $1,020.
WRL-053040-1 - Windsor Sr., Iron, 200cc Head, 64cc, 2.02"/1.60" Valves, 1.250" Single Valve Springs (.560"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $940.
WRL-053040-2 - Windsor Sr., Iron, 200cc Head, 64cc, 2.02"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $1,040.
More Windsor Sr. Head Information:
(-1) models get .560" springs that have 100# seat pressure.
(-2) models get 'racemaster' forged valves and .600" springs have 125# seat pressure.
(-3) models get 7/16" rocker studs, 'severe duty' forged valves, and 10* locks.
Intake Port Gasket – Fel-Pro 375-90361 or equivalent.
Exhaust Port Gasket – Fel-Pro 375-1415 or equivalent.
Head Gasket – Fel-Pro 375-9333PT or 375-1011-2 or equivalent. Caution: 375-1011-1 is not recommended.
Head Bolts and Studs – 7/16" with bushings or 1/2" Standard.
Spark Plugs – NGK 2817, 2405, 4323.
Maximum Angle Mill - .175"
Flat Mill - .007” per cc (approximate).
Maximum Flat Mill - .040" (intake seats).
Airflow Chart for World Product Windsor, Sr. Heads:
Inches - CFM - CFM
0.100 - 061- 052
0.200 - 125 - 099
0.300 - 163 - 122
0.400 - 198 - 138
0.500 - 220 - 151
2.02" in./1.60" Valves.
Bonus Head Information:
Valve Angle:
The valve angle number refers to the angle of the intake and exhaust valves in relation to the head's deck surface.
A shallower valve angle (18*) is better than the steeper valve angle (23*). The 18* head will have the valve over the cylinder head, creating a straighter shot to the combustion chamber. There are a few reasons for it being better as well:
1. The shallower valve angle allows the cylinder head designer to use a smaller volume combustion chamber to help boost the engine's compression ratio without going to large-dome pistons.
2. Valve location is important. For example, the valves in a conventional 23* head are .275 in. from the cylinder bore centerline. When the valves are close to maximum lift, they become shrouded by the combustion chamber and the cylinder walls. That hurts the engine's ability to breathe--and that hurts horsepower.
3. In 18 degree heads, the valves are right on the cylinder bore centerline. The valves are also relocated to position the intake valve closer to the bore center, and the exhaust valve closer to the cylinder wall. This unshrouds the intake valve at maximum lift and allows the use of bigger valves.
I'd love to see a comparison with TFS CNC'd 205cc heads vs. AFR205cc heads on the same day, same dyno, same operator if any of you have seen one.
Chris
Chris
Well no dyno information, which would be much better but here is a little comparison:
BOLD shows the advantage to each compared to the other.
AFR CNC 205------------------------------------------------------ Trickflow CNC 205
Inches - CFM - CFM
0.200 - 141 - 125
0.300 - 201 - 180
0.400 - 251 - 211
0.500 - 291 - 225
0.550 - 301 - 228 (TW info not given)
0.600 - 306 - 231 (Exhaust Tie)
0.700 - 310 - 235
Inches - CFM - CFM
0.100 - 071 - 056
0.200 - 144 - 112
0.300 - 220 - 150
0.400 - 270 - 192
0.500 - 299 - 220
0.600 - 316 - 231
AFR 205:
Valve Angles: 23* for Intake and Exhaust.
Trickflow 205:
205cc Head, 65cc, 2.02"/1.60" Valves, 1.460", Dual Valve Springs w/ dampner (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. $1,990.
66cc exhaust port.
Valve Angles: Intake is 15* and Exhaust is 17*.
Looks like a nice even match to me...the Trickflow has the intake side 'won' and the AFR has the exhaust side 'won' (maybe a bit better for expending the compression for boosted application) and save $140.
Inches - CFM - CFM
0.200 - 141 - 125
0.300 - 201 - 180
0.400 - 251 - 211
0.500 - 291 - 225
0.700 - 310 - 235
Inches - CFM - CFM
0.100 - 071 - 056
0.200 - 144 - 112
0.300 - 220 - 150
0.400 - 270 - 192
0.500 - 299 - 220
0.600 - 316 - 231
AFR 205:
Trickflow 205:
66cc exhaust port.
Wow, thanks for the effort you put forth, here. These are the manufacturer's numbers, right? With flow benches things like pipe (?) diameter and pressure make a difference. Do you know off-hand if they were the same?
Thanks,
Chris
Chris - The AFR flow numbers are from AFR and the Trickflow numbers were from Trickflow:) They are both under 28 inches of water pressure for testing but the pipe sizes were slightly different for the test.
The AFR's pipe is not listed and the TW's had a 2" pipe. On a side note, the AFR 225 test was done with a 1 7/8" pipe. So I would presume since they only noted the 225cc test, the 165, 185, 205cc test were done with the same pipe size, possibly a bit small for the 205cc AFR's. Just an idea...
It appears the differences between intake and exhaust could easily be 'made-up for' with certain cam specs...bias towards one side or the other.
BK Cauley - I'll get you some quick info, I should have time here soon for you...
If you're referring to the numbers trickflow posted on their website for the AFRs, I think you'll find that they took their numbers from the manufacturer. Hence, the numbers are originally from AFR.
Things like the pipe diameter and pressure can make a significant difference in test results when you're talking about heads that flow so comparably to one another.
Either way, I'll bet whichever head one goes with, they'll be happy with. I'm just curious because I made my decision to buy the AFRs before the TFS 205 CNC heads were available.
Chris
I agree, either one is going to do well and appear to be very nice heads!
The AFR flow data is from AFR's website. The Trickflow flow data is from Trickflow's website.
Oh, my AFR 205 heads with the "nitrous porting" option flow approximately 20cfm more on the exhaust side from like .400-.700 lift. I can't remember the exact numbers, but AFR will give exact #'s on it if you call em. I had them written down somewhere, but lost em.
BloodReign, I've got the 80cc ports on mine.
Theoretically, I'm not sure if it is good bad or indifferent to have larger exhaust ports on a turbo car. I think it'd be good because it improves flow, which should mean quicker evacuation of the exhaust from the cylinder and hence less reversion. And, I can't see why the decreased exhaust velocity from the ports would hurt performance. After all, I don't think turbocharged engines take advantage of exhaust scavenging the way n/a and blower engines do. It's just all speculation on my part, though.
Chris
I have seen a back to back comparison dyno test on AFR 205's and TFS 205's. Both were very similar in power. I think that both were nearly identicle to the top end of the tach where the TFS ended up with a peak of about 5 to 10 hp better but IIRC the AFR's had slightly better numbers in the lower rpm's. They were so close I would probably use the cheapest of the two because you wouldn't be able to feel any difference. The test was in one of the mustang mags I don't remember which though.
BTW, Very nice comparison between the heads alot of time went into this. The only thing I see missing is the TFS 185's
rj - Thanks, I got some Trickflow Ported Track 185 information up there:
Inches - CFM - CFM
0.100 - 072 - 058
0.200 - 142 - 112
0.300 - 216 - 150
0.400 - 258 - 192
0.500 - 287 - 220
0.600 - 301 - 231
BloodReign/Fast Driver - So does the 'nitrous porting' add 10cc (70 to 80cc) on those 205's? BloodReign, that would be nice if you could 'find' those numbers again:)
In case anyone is interested, here is some stock LS1 head information:nice:
Airflow Chart for stock LS1 Heads:
Inches - CFM - CFM
0.100 - 067 - 052
0.200 - 122 - 097
0.300 - 178 - 133
0.400 - 215 - 156
0.500 - 219 - 170
0.550 - 223 - 176
0.600 - 227 - 180
Chamber Volume - 66.67 cc
Intake Runner Volume - 200 cc
Exhaust Runner Volume - 70 cc
Intake Valve Diameter - 2.00"
Exhaust Valve Diameter - 1.55"
Valve Angle - 15* for Intake/Exhaust
comparison between afr and trick flow 185 ported heads
prices from treperformance.com
Inches - CFM - CFM
-------------AFR --------trick flow
0.200 - 142 - 118-----142 - 112
0.300 - 200 - 164-----216 - 150
0.400 - 255 - 200-----258 - 192
0.500 - 285 - 210------287 - 220
0.600 - 295 - 213------301 - 231
total -1177 - 905------1204- 905
cost-------$1585 ----------$1816
price on afr heads include upgraded pushrods
Inches - CFM - CFM
Is this a different AFR 185 than what is posted above? The numbers are significantly different.
