Build Thread '83 T-top Coupe - Cliff Notes Edition
Davedacarpainter
I think I've messed my pants
SN Certified Technician
Nov 28, 2015
11,398
10,966
193
58
Discordia
Soooo, It’s fully welded in. Some welds were easy and turned out decent
and then there’s the pinch weld:nonono:.
I knew going in it would be a pita and I wasn’t disappointed. I went along the bottom of the seam and placed tack welds down the entire edge of the seam. Like 18 bagillion spot welds. I figured this would stop the crap from coming out of the seam and make for maybe a prettier weld. As usual, I figured wrong. I persevered and did the whole seam though. It’s ugly as hell, but it can be ground down nice and pretty fairly easy
Once I dress those welds I’ll be able to see areas that might need some touch up welds.
It’s disappointing in a way not being able to figure this pinch weld area out. But it’s great to have it over with.
So, here’s what’s coming. Tomorrow night I’ll be dressing those welds. I’m not sure if it’ll all be done tomorrow night or not. Right now I’m planning for two nights of clean up. Then paint Friday and on to the rear end for the weekend.
  • Sponsors(?)
Davedacarpainter
Nov 28, 2015
11,398
10,966
193
58
Discordia
Ok, all I got done tonight was the pinch weld area. This much just about had me worn down to the nub.
It still needs some evening out with a grinder wheel. That’ll be tomorrow night.
It needs about another fifteen minutes of work. All this will be smoothed when I get to the bodywork stage on the body. Tomorrow I’ll get all the welds on the sfc side smoothed as well as the finishing of the pinch weld area.
So far it looks like I’ll be dropping the IRS this weekend. I need to go buy some things (partially tools) to go on with this step.:taco:
First is an extra jack. I’ve been wanting a larger one than my little bitty sucker I have now. I’ll need two to safely crawl under Booger to unhook the IRS. Then I’ll need some decent storage containers for the odds and ends I take off the IRS frame.
I‘ll be stripping it down completely so I can have an easier time fitting it up as I do the new uca area support, and then the hard tail. I’ll get it powder coated after the hard tail is done.
This is on page 295 of the full thread! Seems to be a lot of bull:poo: going on over there!
Davedacarpainter
Nov 28, 2015
11,398
10,966
193
58
Discordia
So, super genius here woke up with an idea.....it kind of worked.
So this puts me somewhere slightly above idiot and quite a ways below genius. Definitely not moron though.
I would have hit genius had I done this idea prior to ever dressing the welds in the first place. So, the idea is to measure down 1” below the top edge of the pinch weld and run a piece of 3/4” tape along the seam and grind a hard line all the way down the seam (The reason for 1” is that it allows for about 1/8” of weld below the actual pinch seam). Make it where you can still see the separate connecting pieces, the pinch weld and the support. I would love for it to be smooth metal the whole way down, but reality of welding the seam and getting clean welds isn‘t possible for me. Plus this side’s pinch seam was hammered crap when I got it out of the SY.
So pictures. First one, before super brain came along.
Next with the line ground along the seam. Keep in mind this would be more visible had I started this before having done the initial grind. It doesn’t look real straight, but that’s mostly an optical illusion due to the different slants of the weld. The seam area will easily cover with a thin layer of mud and look uber cool.
I got a bit into the sfc side. That was fun. It cuts fairly easy, it’s just that the carbide bit leaves :poo: ton loads of little super duper sharp shards of metal. I had to stop because I didn’t have back up charged batteries...... :nonono: damned nube.
So, the lessons learned from this side will be put to use someday when I go back to the other side. I still need to finish the pinch weld area on that side.
This means I’ll still be grinding tomorrow. NBD though. Even if it took into saturday morning, I’d still have lots of time to change up how the car is setting and get the IRS out.
BTW Chris @Hoytster ? You’re right about that clearance between the IRS and the uca mount being tight! I hadn’t looked at that before. I’ll do a crap load of measuring with and without the IRS frame in before ever welding.
Davedacarpainter
Nov 28, 2015
11,398
10,966
193
58
Discordia
Ok, I finally got the IRS dropped, yay! That last bolt on the front left was the only one that required me to be fully under Booger again. I’ll get it stripped down tomorrow.
Now, here’s the next area of modification. The upper control arm mounts. You’ll notice five different areas of concern for me. First in green are the dumbo ear mounts that normally clear the IRS by the narrowest amount, and I mean narrow, like 1/4” separation. They’ll be gone. Got to go back to hf and get a few spot weld cutter bits.
Then comes the other three that I want to keep and maybe slightly modify. In yellow is the backing plate that’s welded to the floor pan. I think it’ll stay.
The other two in red are the support plates for the rear seat belts. I need to maintain them. Though they may be slightly modified and trimmed at the top so the 2x2 tubing will fit. Then I’ll weld the trimmed part to the new tube.
Here it is higher up in the air than it’s been in a long time.
This final picture just seems to excite me, lol! I’ll be playing under there for a bit. I’m looking forward to making that trans tunnel all green.
I didn’t get much done this weekend, but I’m set for the next stage tomorrow!
Tomorrow’s plans are to just strip down the IRS and stop by hf to get the spot weld cutters.
This IRS is going to be costly, I’ve already added up $2500 in modifications for it. That’s OK though, it’ll be totally bitchi’ when it’s done.
Davedacarpainter
Nov 28, 2015
11,398
10,966
193
58
Discordia
To start off, the chrome socket did just fine. :nice: Plus the impact did just great, no problem taking off the castle nut on the half shaft.
Here’s something peculiar, look at the banjo bolt holding the brake line to the caliper. It was like this on both sides. I couldn’t get it off in a timely, so I clipped the hose and pulled the calipers off.
Here it is nekked.:eek: It does weigh around 50-60lbs. Feels like a feather after moving it so much with it assembled.
Here’s a pile of parts early.
And a pile of parts finished up.
It‘s time to go buy those spot weld cutters now. I forgot to get them before because I’m stupid.....:scratch: Tomorrow night I’ll be up Booger’s rear to my elbows.
Reactions: Monkeybutt2000
Thread starter Similar threads Forum Replies Date
Davedacarpainter Build Thread '83 T-top Coupe - IRS is Torn Down, On to Something Real 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5982
Davedacarpainter Fox 1983 T-top Coupe - $1000 - New Buffalo Butt Beer 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 571
B SOLD 1983 T-top Coupe Fox Body Mustangs For Sale (1979-93) 5
91svtcoupe Official Thread...For 1981 T Top Coupe Build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
I Modded 84 T-Top coupe **OHIO** Fox Body Mustangs For Sale (1979-93) 1
8 1987 5.0 coupe with t-tops!!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 52
S 67 mustang coupe vinyl top 1965 - 1973 Classic Mustangs -General/Talk- 3
C 88 coupe top end question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
Trbofox Started the 84 t-top coupe 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 597
S&B project T top coupe update for those who care 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 52
R Wanted: Two top pieces of windshield trip on 67 coupe Engine and Power Adder 0
stang_hp T-TOP coupe 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
stang_hp T-TOP coupe Fox 5.0 Mustang Tech 7
7 WTB 69 coupe vinyl top trim peices Engine and Power Adder 16
7 WTB 69 coupe vinyl top trim peices Engine and Power Adder 6
TC93 People with t-tops,, need little help..( t-top coupe) 56k warning Fox 5.0 Mustang Tech 3
TC93 Finally little more progress made on 84 t-top coupe project..(56 no go) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
F vinyl top on a standard coupe Classic Mustang Specific Tech 2
TC93 Some progress on the T-top coupe.. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
J T-TOp coupe 4 cheap, wish i had the money :( 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
90blacknight Pics of fox body coupes with T-Tops? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Scootro Have you ever seen a 86' t-top coupe 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
D 67 mustang coupe hard top weight 302 Classic Mustang Specific Tech 11
D Just made the Turbo Coupe a targa top. alot easier than i thought 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
I T-top kit for 94-95 coupe? 1994 - 1995 Specific Tech 3
2 targa top conversion for 94-04 coupes Mustang Sound & Shine All 8
J Vinal Top Removal on 66 Coupe Classic Mustang Specific Tech 4
8 fox body coupes with t-tops? Special Production 7
D Buying an 86 t-top coupe any good or bad about an 86 2.3 2.3L (N/A & Turbo) Tech 13
C 73 convertible top Slows down then stops starter then the Starter motor relay clicks 1965 - 1973 Classic Mustangs -General/Talk- 8
5 Top End Reccomendations 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
S TMI T-top headliner installation trouble getting retaining strip on 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Trickflo 1987 LX T-Top worth buying? What is it Worth?!?!? 23
W Electrical Convertible Top Switch spade connectors pulled loose (92 Mustang LX Conv.) Fox 5.0 Mustang Tech 4
Mustang5L5 Reference 1981-1988 Mustang T-top repair and maintenance. manual Resource Discussion Forum 0
Gfallon1 99 convertible top 1996 - 2004 SN95 Mustang -General/Talk- 0
B 90 MUSTANG CONVERTIBLE TOP 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
M New member- Where to buy a red convertible top? The Welcome Wagon 1
A Fox Looking to buy fox top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
L Help with TrickFlow Top End Kit Fox 5.0 Mustang Tech 6
D Engine The Secret of the Fox body Starter top bolt. Shhhh!!! Fox 5.0 Mustang Tech 4
Mixveez First car 86 T-Top 4 eye Fox 5.0 Mustang Tech 67
1989FoxFan Interior and Upholstery Two different sizes of cables for Top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
H New guy with an 87 drop top gt The Welcome Wagon 2
F For Sale FS: 88 T-top GT hatch, owned 32 years Fox Body Mustangs For Sale (1979-93) 6
1989FoxFan Interior and Upholstery [Solved!] Should I replace the pads and cables for my top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C 2005 convertible top won’t go back up 2005 - 2014 Specific V6 Tech 0
Eilermoon '03 Convertible top stuck SN95 4.6L Mustang Tech 16
N knocking noise from top of the motor 1996 - 2004 SN95 Mustang -General/Talk- 2
T Disable parking brake for convertible top 1996 - 2004 SN95 Mustang -General/Talk- 1
