Over the years I was told there are 3 rear ends. Open (one tire spins no matter what), Limited slip (one tire spins unless traction requires both) and Posi (both tires spin no matter what). Therefore you can't truely have a posi unit if it has a limited slip. Now I jacked up the rear and spun the tires. Both tires spun at the same time in the same direction hense (posi, short for positive traction locked differential) limited slip will spin one tire in one direction and the other in the other direction when jacked up. I read one time in 5.0 magazine once that the '86 5.0 mustangs came with a TRUE POSI rear differential not the generic term given to the Limited slip rear. I tried like hell to find that copy in my 8 boxes of saved magazines but, no avail. Ford confirmed the "P" in the tag did truely mean a posi rearend. example 3O08 is 3.08 open rear, 3L08 is 3.08 limited slip and 3P08 is 3.08 posi. Unless the Ford parts guy is a Gm guy they stated it as Posi. I had an '86 mustang vert about 6 years ago and it had the same tag and when I turned tight corners the rear would shift the car sideways a little because the rear was posi. Now I never pulled the rear apart to see the internals so I didn't know what the posi unit was. My brother put a full spool in his and it acted the same. Yeah I could dump $500.00 dollars for a locker for mine and get the clunking associated with the posi lock up, or put a full spool in and spend 500.00 redooing the rear at the same time or get an '86 posi rear with 75,000 miles for $100.00. I just didn't know how strong they were.
