88 GT 5 lug conversion
Red50Fox
131
Massachusetts
I'll probably catch some grief for this (there are too many posts to scour through looking for answers) I managed to pick up front spindles and front and rear brakes (rotor, caliper, mounts, dust shields, booster and M/C etc.) from a 95 GT for $250.00 (good price from what I understand) I'm planning for a future 5 lug conversion and need a bit of info. on brake lines and cables (emergency brake) that I'll need.I'm planning on doing the 83 - 92 ranger axle approach with SN95 17" Pony rims. I know I'll need rear brake mount (LMR or North Racecar) and a bunch of other stuff. I'm concerned about the stuff that I don't know about. So if folks want to toss some information on what I'll need my way it is greatly appreciated.
Thanks
Basic guide right there in post 220 with a couple substitutions. Rear axles and brackets as you are aware of, and the MC that matches the calipers you have. (94/95 GT master)
Highly recommend not running the 94-98 front calipers and picking up a set of 99-04 2-piston calipers...but your call there
Reactions: 2 users
The brackets are part of the caliper up front. It's the black bracket shown here
When using the 99+ calipers on 94/95 spindles, a small bit of ckearancing is required for the two pistons. Bolt the calipers on off the car and you'll see what needs to be clearanced around the mounting holes
This is a 96+ spindle that is cast with the mounting holes clearanced slightly
I think I saved this pic from a post on here, so give credit to whomever first posted, but this is what you want to grind off. This swap is in my future, so I’ve been saving anything that’ll help along the way.
Reactions: 1 users
I'm looking forward to it. I was looking for the notes I saw on wheels that will compliment the swap. I was thinking about 17" pony wheels but am open to suggestions and opinions. It's an 88 GT with (soon) 95 GT brakes and spindles.
... and now I know. Thanks. I'd like to run 17" and these seem to have an offset that "should" fit based on what I've read (30mm). Though I have no hands on experience with these so I'm going based on what I've read. I was certain that I saw (and I should have copied / bookmarked) a page that indicated the factory rims that folks had actually used. I'll keep searching, I have the time...
@Mustang5L5 I managed to find a set of split 5 spokes with tires (about 1000 mile on them) for $250 seemed reasonable to me. I never heard back from you. What size tires are you running on the sn95 wheels from the post above? I think 245/45R17 is supposed to be the norm. Let me know
I'm sorry.
235/45/17 up front, and 255/45/17 out back.
If I could do it over again, i'd go with a 245/45/17 up front. The 235 does make fitting the wheel easier due to the shorter diameter, but I think I could squeeze the 245/45/17 in there fine. The 235 looks a bit narrow at some angles
The wheels I have are in good condition, as are the tires but the tires are 225 all around. That is what the dealer sold the car with. I'm going to use them just to get the 5 lug done but want to get 245s. My neighbor has a 96 - 98, not sure with the same wheels. I think he's selling the car, maybe he'll do a swap :lol:
