alright so my fox has an issue with its idle on a cold start it'll jump up to atleast 1500-2000 Roma almost stall out but idles prettt normal after driving for an hour or stopped at a red light the cars rpm will drop about 150 Rpms and start idleing roughky but won't stall out accelerates poorly but drives perfectly fine I checked for vacuum leaks and nothing at all. I did pull some codes and swapped out the sensors that had the codes go off but CEL remains on and rough idle is still there I'll post the codes later as I don't have them atm
