Electrical 89 GT Alternator upgrades, battery not holding charge
FetusLasVegas
78
37
Chicago
Hey all,
Today I installed my new 130A alternator upgrade with the new 4ga wire. Up until the install I had no charging system issues at all. Before the install my voltage gauge typically read around the middle. I got everything buttoned up after the install and started the car. The voltage gauge was way low, about one notch above the red. I let it run for a bit and now my car won’t start. I checked all the wiring connections and everything is tight. LMR said they will send me a new alternator on Monday. I was wondering if there is any troubleshooting I could do to see if something else is the problem in the meantime. Thank you!!
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,374
2,708
234
75
Dublin GA
lowendmac.com
Alternator troubleshooting for 86-93 5.0 Mustangs:
Never, never disconnect an alternator from the battery with the engine running. The resulting voltage spike can damage the car's electronics including the alternator.
Revised 28-Nov-2018 to add warning that the instrument cluster must be in place and working for the alternator to charge
Red color text applies to cars with a 3G alternator.
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous tests for correct interpretation.
Simple first step: Remove the alternator and take it to your local auto parts store. They can bench test it for free.
Use a safety pin to pierce and probe the insulated connectors from the rear when doing tests with the connector plugged into its' mating connector.
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link for the yellow/white wire has open circuited.
Engine off, ignition on, battery fully charged:
1.) The alternator MUST have the instrument cluster in place and working properly. The alternator warning light is a part of the charging circuit. The alternator warning light should glow. No glow, bulb has burned out or there is a break or bad connection in the wiring between the regulator plug and the instrument cluster. The warning light supplies an exciter voltage that tells the regulator to turn on. There is a 500 ohm resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator.
Measure the voltage on the Lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp, the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed voltage regulator. This is an actual measurement taken from a car with a working electrical system. If you see full or almost full12 volts, the regulator has failed.
Engine on, Ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0 volt. If the battery measured across the battery is 15.25 volts, you should see 14.50 volts
Familiarize yourself with the following application note from Fluke: See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachments\568093
You will need to do some voltage drop testing of several of the wires.
Start looking for these things:
1.) Bad diode(s) in the alternator - one or more diodes have open circuited and are causing the voltage to drop off as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Do the voltage drop test as shown in the Fluke tech note link. Measure the voltage drop between the alternator frame and the battery negative post. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
3.) Bad regulator that does not increase field current as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
4.) Bad sense wire - open circuit in sense wiring or high resistance. The yellow/white wire is the voltage sense and power for the field. There is a fuse link embedded in the wiring where it connects to the black/orange wiring that can open up and cause problems. Disconnect the battery negative cable from the battery: this will keep you from making sparks when you do the next step. Then disconnect the yellow/white wire at the alternator and the green fuse link at the starter solenoid/starter relay. Measure the resistance between the alternator end of the yellow/white wire and the green fuse link: you should see less than 1 ohm. Reconnect all the wires when you have completed this step.
5.) Bad power feed wiring from the alternator. Use caution in the next step, since you will need to do it with everything powered up and the engine running. You are going to do the Fluke voltage drop tests on the power feed wiring, fuse links and associated parts. Connect one DMM lead to the battery side of the starter solenoid/starter relay. Carefully probe the backside of the black/orange wire connector where it plugs into the alternator. With the engine off, you should see very little voltage. Start the engine and increase the load on the electrical system. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
Alternator wiring diagram for 87-93 Mustangs.
attachments\568094
The following are diagrams courtesy of Tmoss & Stang&2birds
Alternator wiring diagram for 94-95 Mustangs.
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch
100 mV Ground
0 mV to <50 mV Sensor Connections
0.0V bolt together connections
Alternator wiring circuit
Notice the green wire connects to a switched power source. The circuit contains a 500 ohm resistor in series between the switched power and the alternator. Connecting it to switched power keeps the regulator from drawing current when the engine is not running. The resistor limits the current flowing through the wire so that a fuse isn't needed if the wire shorts to ground.
Also notice the sense wire connects to the starter solenoid and it is fused. It connects to the starter solenoid so that it can "sense" the voltage drop across the output wiring from the alternator.
Fuse link for 86-93 Mustangs
Replacement parts:
14 gauge fuse link for stock alternator.
Bussman BP/FL14 Fusible link
AutoZone
Dorman - Conduct-Tite 14 Gauge Fusible Link Wire Part No. 85620
Advance auto parts #85620
Pep Boys - SKU #8637594
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
https://www.stangnet.com/mustang-forums/attachments\21328
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
mikestang63
Aug 27, 2012
9,980
6,779
204
In the garage
three things
  • please tell me you did not reinstall the stock power wires- if so TAKE THEM OFF and tape them off. You only want to use the new 4 gauge power wire with a 150 amp fuse going to the Starter solenoid.- same side as the + battery cable
  • Second, you MUST install a new 4 gauge ground cable from the chassis to the block
  • finally, did you connect the stator wire from the 2g harness to the new 3G alternator?
FetusLasVegas
78
37
Chicago
To specify, I installed the full 130A upgrade kit from LMR, it includes the 4ga power wire upgrade, and the 3g alternator harness upgrades. Everything was installed following their youtube vid to a T
three things
I did not uninstall or reinstall the stock power wires. Per the LMR vid, I added on the 4ga power wire and zip tied it along the path of the old. The power wire included the fuse.
Noted. That is not mentioned or addressed with the LMR upgrade. I do plan on doing this eventually.
I spliced in and connected the 2g wires into the 3g conversion alternator side wiring harness per the instructions and vid from LMR.
Not quite sure how this applies as I used the 3g conversion harness provided. Care to elaborate?
FetusLasVegas
78
37
Chicago
I am not familiar with the LMR conversion harness. Care to elaborate?
Sure thing. It comes with the proper attachments for the 3g alternator. Two ring connectors to attach the two black wires to the bolt on the back of the alternator where the 4ga power wire also attaches. The yellow and green wires splice into the connector and it has a proper stator wire attachment. Hope this helps. It’s all by memory. I can find the exact instructions and try to upload them if not.
General karthief
Mod Dude
Aug 25, 2016
18,841
6,218
193
polk county florida
Yes, they now have ring terminals on the ends and connect to the back of the alternator where the 4ga power wire connects
https://www.stangnet.com/mustang-forums/threads/87-93-130amp-alternator-install-how-to.870572/
https://www.stangnet.com/mustang-forums/resources/3g-alternator-fox-upgrade.18/
Here are two links on this subject. I would suggest reading through both threads and decide for yourself. If in doubt, find an electrical engineer and ask him.
Wait, I think one of the members in the thread is like a super electrical something or another (aerospace engineer maybe).
I would go with Dan's write up and remove the two wires in question.
And I don't carry a fire extinguisher in the exxon valdez
The dump truck has one, probably really old and should be replaced. I am such a poor owner/operator.
FetusLasVegas
78
37
Chicago
Both are great reads, thanks! I will take the two black 10ga wires out of the equation. Today is the first day I’ll have time to follow jrichker’s troubleshooting guide to find out why my battery isn’t charging. I’ll follow up with what I find.
Reactions: General karthief
FetusLasVegas
78
37
Chicago
attachments\568093
attachments\568094
300 mV Switch
100 mV Ground
Replacement parts:
AutoZone
HVAC vacuum diagram
Fuse box layout
Starter circuit
Thank you for your great electrical troubleshooting guides!! Had the alternator tested today at my local parts store. Passed the light test and failed the energize test. Looks like I received a doa alternator?? The replacement comes tomorrow. Hopefully it gets here before I have to leave for work.
jrichker
Mar 10, 2000
27,374
2,708
234
75
Dublin GA
lowendmac.com
I am glad to be of service.
I hope to enable people to spend less time chasing rabbits in an attempt to fix problems so that they can spend more time enjoying driving their Mustangs.
FetusLasVegas
78
37
Chicago
attachments\568093
attachments\568094
300 mV Switch
100 mV Ground
Replacement parts:
AutoZone
HVAC vacuum diagram
Fuse box layout
Starter circuit
Engine off ignition on test 1 shows a steadily rising mV reading, not 12V. Everything was fine before installing the new alternator. I don’t see how a wiring problem could come up now.
Blown88GT
2,161
514
164
Palm Beach Gardens, FL
I would go with Dan's write up and remove the two wires in question....
That would be me. LMR & all the others know nothing electrical. I once wrote to the editor of MM&FF on this subject & they published it. Too long ago for anyone to remember. Just follow what they told you here in this thread.
FetusLasVegas
78
37
Chicago
Awesome, good to know and thank you for your help. Aside from the general problems that go with the original 75a alternator, my car was running perfectly fine before installing the 130a. My fuse on the 4ga power feed is good. Voltage is the same at the power post on the alt as it reads at the battery. Also getting the same V reading at the yellow wire with key off and the harness plugged in. I’m not getting a proper reading with the key on and the harness unplugged on the green/red wire. I replaced the alt warning bulb which was burned out and visually inspected the in line resistor on the gauge cluster. Still getting a bad read on the grn/red. No changes were made on the wire other than the conversion harness being spliced in on the alt side. What would you suggest I do next?
General karthief
Mod Dude
Aug 25, 2016
18,841
6,218
193
polk county florida
Have you checked the battery condition?
what voltage is the alternator putting out at idle with nothing turned on and then with everything on.
FetusLasVegas
78
37
Chicago
I had the battery tested, and they said to replace it. I can check the outputs in the morning. How do I do that. My plan as of right now is buy a new batt in the morning and see if that changes anything.
