89 LX 2.3L Sputter at certain RPM range
Tavis
31
89 LX 2.3L hatchback.
Within the first 5min of driving, typically I notice that it will start sputtering with loss of power between RPM range 2000 to 3000RPM. Below or above I do not have the sputtering issue. After driving for 5min or more, the issue disappears. Until I let it sit for an hour or two and drive it again. And when this happens, if you have the windows down, you can smell very rich exhaust. Which obviously tells me it's not firing and burning all fuel when it happens. No colored exhaust either.
Runs alright other than this.
Example: I can drive to my parents house (12min away) and it will typically sputter shortly after leaving the driveway of my house. This happens in all gears (5 speed) between RPM of 2000 to 3000. Worst over 2500 to 3000 RPM and in third and fourth gears. If I go above or below that, it stops. If I push in the clutch, it idles fine. I can be at my parents house for an hour or so, start'er up to go home and get a couple miles down the road and it will sputter slightly. Seems like it is worse the longer it sits. Cold or hot outdoor temps don't seem to make a difference.
One time this week, after it sat for maybe a week, the sputter was so bad the entire car bucked when it lost power.
Plugs? Distributor? Injectors? Something else?
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
J 2001 MUSTANG V6 SPUTTERS WHEN ACCELERATING SN95 V6 Mustang Tech 8
W Sputter on acceleration 4.6 SN95 4.6L Mustang Tech 2
silverlx50 Engine UPDATED WITH FIX IN POST #49 Help with sputter issue with cold starts Fox 5.0 Mustang Tech 49
Brads2000 Need help, 2000 3.8 sputtering The Welcome Wagon 3
5 Strange misfire or sputtering Fox 5.0 Mustang Tech 5
R Turns Sometimes Starts Sputters and Shakes once started 2005 - 2009 Specific Tech 0
Barron91lx Sputtering until warm Fox 5.0 Mustang Tech 19
D Engine 2002 V6 Sputtering On acceleration SN95 V6 Mustang Tech 0
CFL2013 2013 sputters then stalls cold 2010 - 2014 Specific Tech 1
T 1996 Mustang GT - sputtering,hesitating,shaking while accelerating 1996 - 2004 SN95 Mustang -General/Talk- 3
B 1965 289 V8 Idles great sputters and stalls on the road after minute restarts before stalling 1965 - 1973 Classic Mustangs -General/Talk- 5
H 88 Starts sputters stall immediately Fox 5.0 Mustang Tech 6
G Engine 85 302 holley carb. Car suddenly started to bog and sputter untill it stalled Fox 5.0 Mustang Tech 3
Rogdoger45 Sputtering SN95 4.6L Mustang Tech 0
F 79 mustang sputters Fox 5.0 Mustang Tech 1
B 2005wot Engine Sputters 2005 - 2014 S-197 Mustang -General/Talk- 1
M Engine 88 Gt Barn Find Sputtering Issues? Fox 5.0 Mustang Tech 11
RysRed96GT Intermittent Sputtering Under Load 1996 - 2004 SN95 Mustang -General/Talk- 7
A Low Rpm Engine Sputtering Help Fox 5.0 Mustang Tech 3
H 94 Gt Sputter Issue 1994 - 1995 Specific Tech 13
B 88 Mustang Gt No Power, Sputters Etc. Fox 5.0 Mustang Tech 4
J Sputtering Problem 1996 - 2004 SN95 Mustang -General/Talk- 2
RysRed96GT Sputtering Under Load At Low Rpm (<2k) 1996 - 2004 SN95 Mustang -General/Talk- 2
Knowbody Engine '91 5.0 Pop & Sputters Around 4k Rpm Fox 5.0 Mustang Tech 11
Pittfann97 High Speed Sputter 2005 - 2009 Specific Tech 0
S 1996 Mustang Gt Sputters Under Throttle 1996 - 2004 SN95 Mustang -General/Talk- 6
Craftystang 88 Mustang Sputter Problem Fox 5.0 Mustang Tech 25
M Sputtering 2014 V6 2010 - 2014 Specific Tech 0
Jordan Warta Car Sputtering And Dieing When Starting After Car Sits 6+ Hrs?? Fox 5.0 Mustang Tech 3
grnhays Spits And Sputters Fox 5.0 Mustang Tech 18
O For Those Who Care Fox 5.0 Mustang Tech 5
s2s281sc Engine 2000 Saleen Series I I ; Mil Status Off, Running Rich, Idle High SN95 4.6L Mustang Tech 34
L Help! Car Stalling, Sputtering, Died! 1996 - 2004 SN95 Mustang -General/Talk- 11
omnitech Erratic Idle And Sputtering Upon Acceleration Fox 5.0 Mustang Tech 2
studio2jeff 1990 5.0 Ho Sputters And Dies After Like 30 Min Of Driving Fox 5.0 Mustang Tech 12
flashback87 Please Help With Low Rpm Warm Hesitation/sputter Fox 5.0 Mustang Tech 10
sharp2377 Carbed 351w Sputtering Badly Fox 5.0 Mustang Tech 12
G Sputtering Below 2k Rpm SN95 4.6L Mustang Tech 11
sharp2377 Engine Sputtering Suddenly, Magnet Broken In Dist? Fox Engine Swaparoo 1
AUNNB3 Help! Sputtering During Acceleration Fox 5.0 Mustang Tech 4
S Sound Of Air Sputtering On Underside Of Car Towards Exhaust Manifold Area. SN95 4.6L Mustang Tech 10
0 Car Sputters And Dies At Idle Help 1996 - 2004 SN95 Mustang -General/Talk- 3
D Sputtering? SN95 4.6L Mustang Tech 6
Anaconda Sputtering 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
CWBx 95 Gt \ Sputtering & Loss Of Power 1994 - 1995 Specific Tech 0
C Out Of Nowhere, No Power, Sputters & Backfires. Same Thing At Idle Under No Load? Fox 5.0 Mustang Tech 28
jessyager '02 V6 3.8L Mustang sputtering and backfiring on acceleration... SN95 V6 Mustang Tech 1
Mike Connell Engine 99 Rough Idle, Sputtering SN95 V6 Mustang Tech 3
K 97 Auto coolant leak, sputtering engine SN95 V6 Mustang Tech 3
M Fuel Car sputters and throws a P0190 code SN95 4.6L Mustang Tech 8
