Hi folks! Been reading for a while on here. Decided to post to see if I could get some help and guidance. Recently bought a 93 hatch 5.0 5sp with a MSPNP2. Other mods would be Edelbrock performer heads, Explorer intake, FoMoCo 47 lb injectors, 70mm Accufab TB, full 2.5" exhaust, and an old school Paxton sn2000 on it. All mods were done before I bought it. Would like to do more to it, but would like to get the tune sorted out before I start adding more to it. Supposedly it was tuned by a shop in Nov of 16. It does run well at wot. But has issues with normal drivablity. At a cold start and ambient temp below say 70*, it will start up fine and idle down fine. A cold start at ambient temp around 90*, it will start drop real low almost dying and run like crap until I baby it enough to get on the road, once I get going it seems to be fine. Hot start does basically the same thing. I've also noticed it seems to have some dead spots while going through the gears less than half throttle or so. Not wot. It happens around 1,800 and again around 3,500. While this happens, I notice the AFR is way lean, like 15-16. It also has a small idle surge 100 rpm or so. Vacuum is around 17-18 stock cam. And a few other issues I can't think of right now. I'm assuming it just needs the fuel dialed in more. But I'd like someone to look over my current tune to see if there's anything else out of wack, before I start messing with it. I really appreciate any and all help! Thanks!
