- Feb 18, 2004
- 28
- 0
- 1
well, I installed today... 96 GT auto convert. = fluidyne radiator , mac chrome hoses , hosetechiques couplers, mishimoto dual fans, canton over flow tank with canton 16psi cap. install wasnt bad at all... if you have a 96 and want the dual fans, order the 94 - 95 models, they dont make one for 96, and the 97 - 99 will not fit at all... the trick to fitting dual fans around ABS set up., first unbolt AC canister, pull it out, reinstall approx 2 1/2 inches under brake lines, drill 2 holes, and reinstall there. the ABS set up , remove 2 upper bolts, under the car in fender theres 2 more bolts and a hook... unbolt those 2 bolts and unhook. then pull back and down, I used 4in spacers and carriage bolts, leave the 2 inside bolts off, and dont hook it back on. = plenty of clearance for the fans, Ive read so many posts on fittment, wasnt that big of a deal, but yes it wasnt fitting at all, unless relocating. also the ground on abs unit will now be too short for stock location. I grounded mine on the bolt I used when i relocated AC canister. works great,,,,
QUESTION!!!??? HOW HOT IS BAD? now that I have everying polished, chrome, aluminum, i left car running for 20 minutes, after install, I couldnt touch anything under the hood. it was insanely hot.. anyone have these chrome hoses, alum rad, dual fan??? Im now concerned to drive the car with that much heat under there.
