99 Mustang P0340 Code Help
Chrisxsvt
Active User
Feb 7, 2017
I have a 1999 mustang just swapped it with a 2002 mustang engine v6 ( sad I know) camshaft position sensor code comes up (only code I get) read some post took my alternator to auto zone for testing it passed read at 130 amps so I switched my camshaft synchronizer with the old one off my 99 ran normal for like 5 minutes then code came back. It runs sluggish and idles high give me what you got !
:bang:
Admin Dude
Jan 4, 1985
25,640
8,350
224
Box behind Walmart
www.stangnet.com
I've seen lots of guys say that they've fixed this by putting a new set of factory wires on. A few even mentioned Jacobs wires although I think one of those ended up going factory replacements as well.
Chrisxsvt
Active User
Feb 7, 2017
factory as in buy them at ford or ford motorcraft from auto zone same thing right?
Chrisxsvt
Active User
Feb 7, 2017
Chrisxsvt
Active User
Feb 7, 2017
Factory as in: Go to Ford service center with your VIN# in hand and order a new set of OEM wires.
92$ :doh: Well I've already replaced the alternator and camshaft sensor + synchronizer with no change so why not I guess :shrug:
Chrisxsvt
Active User
Feb 7, 2017
#12
Got the spark plugs yesterday about to put them on one question tho how do I adjust the camshaft synchronizer? I think it might be off
Car ran like crap I bought just a brand new camshaft sensor and the car actually gained some power but still sluggish
Admin Dude
Jan 4, 1985
25,640
8,350
224
Box behind Walmart
www.stangnet.com
#17
Yep car runs better and has some power but it's not 100% and I still get the camshaft sensor code.
I'm going to do a little more research tonight and I'll post back.
In the meantime, perhaps @COramprat can dig up a resident expert.
COramprat
Drone Driver
Mod Dude
Mar 2, 2003
6,475
376
223
Sea of Tranquility
#18
The cam sensor can cause it to run rough if it isn't installed correctly I believe. I was getting the same code on my old V6 F150.
@wmburns
Chrisxsvt
Active User
Feb 7, 2017
#19
@wmburns
I believe so too I'm not sure how to adjust it or where it should sit exactly so I honestly just threw it on how it was also one more thing that it's starting to do is when I try to start the engine it won't start right up it turns but not on I have to open the throttle think it might be my tps? Only getting one code still with is cam sensor
Chrisxsvt
Active User
Feb 7, 2017
#20
Also I replaced the crank sensor today nothing changed
