A/C idle up control- Low input or High. ?
darryl paarman
205
92
39
ft bragg nc
As warm temperatures have arrived- I'm wanting to get my A/C idle up turned on.
I went into tuner studio- and turned the A/C function on - selected table switch -then low input.
Should this input be set to High? For MSPNP2 ?
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,147
6,054
204
31
Hillsborough county
Its asking when should the input be active, low or high. Low is switched to ground, I will have to check but I dont believe the tableswitch pin us capable of accepting 12v.
Blown88GT
2,046
468
134
Palm Beach Gardens, FL
DIYPNP needs a 2N2222 which it has internally but is not wired up.
Relay 1 & 2 circuits are 2N2222 rated at 600 ma which activate the relay coil directly via pin-54 & provide sensing to pin-10.
Pin-10 is used as a sense to determine when the Clutch Cycling Pressure Switch is closed.
MAIN BOARD.......EDGE PIN CONNECTOR NAME.......ECU PIN
Relay1-In to PT6........WAC (WOT A/C Cutoff)
Relay1-Out...............WAC (WOT A/C Cutoff).............54
Used for AC Idle-up
Relay2-In..................ACCS (A/C Cutoff Sense)..........10
Relay2-Out to PA0.....ACCS (A/C Cutoff Sense)
Thread starter Similar threads Forum Replies Date
S Another Idle surge post with microsquirt Digital Self-tuning Forum 5
91mustanglxcoupe 89 Mustang MS3 gold box tuner studio idle control and injector dead time Digital Self-tuning Forum 15
Rdub6 Engine 1986 Idle Air Control Fox 5.0 Mustang Tech 0
C Fuel 94 Gt Air Idle Control 1994 - 1995 Specific Tech 2
S Idle Air Control Over Speed Error Code - Replaced Everything SN95 4.6L Mustang Tech 5
Joshua H. Taylor 1996 Mustang Cobra Air Idle Control Valve SVT Tech Forum 0
des89stang stock 5.0 throttle body complete with TPS sensor and idle control motor Engine and Power Adder 0
D Idle Air Control swap hope it works SN95 V6 Mustang Tech 5
BigDanTheMan Idle Air Control/Upper Intake Pops Fox 5.0 Mustang Tech 5
D Need to replace my Idle Control Valve is aftermarket ok? Fox 5.0 Mustang Tech 4
1 how to clean idle air control valve 2.3L (N/A & Turbo) Tech 5
A Replacing Idle Air Control this weekend... SN95 V6 Mustang Tech 2
S Idle Air Control, where is it? SVT Tech Forum 3
K Idle Air Control question... 1994 - 1995 Specific Tech 11
bhuff30 Idle control valve? SN95 4.6L Mustang Tech 2
8 1300 rpm idle ? idle air control? please help Fox 5.0 Mustang Tech 2
D Error Code(P0506) - Idle Control System RPM Lower than Expect 2005 - 2009 Specific Tech 3
steve75 idle air control adjustment spacer? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Guero Idle Air Control 1994 - 1995 Specific Tech 11
juiced_94gt I can close the Idle control switch and the car does nothing???? 1994 - 1995 Specific Tech 3
AnthonyR23 Error Codes..... idle.... tps... idle air control Fox 5.0 Mustang Tech 5
tmoneyballin Check engine code: p1506(Idle Air Control Overspeed Error what is this, how do I fix? SN95 4.6L Mustang Tech 3
rickd93_lx idle air control valve? Fox 5.0 Mustang Tech 2
G P1506 - Idle Air Control Overspeed - 03 Cobra SVT Tech Forum 6
MainstreamStang Help, Car Idles Out of Control when Heat or AC on SN95 4.6L Mustang Tech 12
P Where to buy a Idle Air Control? Fox 5.0 Mustang Tech 2
P Where to buy a Idle Air Control? Fox 5.0 Mustang Tech 5
D Help - New Error Code(P0506 - Idle Control...) 2005 - 2009 Specific Tech 1
MustangGT92 looking for the idle control sensor Fox 5.0 Mustang Tech 2
J my idle is out of control Fox 5.0 Mustang Tech 2
88GeeTee WHAT THE HECK controls the idle in these things? Fox 5.0 Mustang Tech 31
Z CFI (Throttle body injection) Idle control Fox 5.0 Mustang Tech 2
gtcobra302 Idle Air Control Valve help Fox 5.0 Mustang Tech 1
Dr_EluSivE oil control and idle Questions 2.3L (N/A & Turbo) Tech 7
Twisted TSB for Idle Air Control Valve? SN95 4.6L Mustang Tech 5
B idle air control valve Fox 5.0 Mustang Tech 14
D Question about idle air control Fox 5.0 Mustang Tech 3
Back2Mustangs Idle Air Control 'Motor' ?? IAC Valve... SN95 4.6L Mustang Tech 4
J bad idle air control Fox 5.0 Mustang Tech 7
D Question about idle air control and throttle body Fox 5.0 Mustang Tech 5
1 Need Experienced Stanger with Idle air control thing Regional Forums and Event Information 5
S Replacing Idle Air Controller..anything to watch our for? SN95 4.6L Mustang Tech 13
dastang2 is a bad idle air control motor causing this SN95 V6 Mustang Tech 3
M Where to buy Idle Air Control Valve? SVT Tech Forum 4
latham83 Egr and Idle bypass Control Fox 5.0 Mustang Tech 1
bmorrisj bad idle air control?? Fox 5.0 Mustang Tech 2
T MS3 AC Idle Up Settings Digital Self-tuning Forum 1
93silverlx50 Engine Car in limp mode, fuel spitting out of tailpipes, missing rough idle Fox 5.0 Mustang Tech 9
markinms Engine Should Auto Trans Be in Drive When Setting Base Idle Fox 5.0 Mustang Tech 7
R Fuel Throttle body idle screw 1994 - 1995 Specific Tech 2
