The heads are 185 afr with a holly systemax upper and lower. Cam will be comp cam hr282xe . Have a 90mm-maf and a 75mm accufab race tb to go on.
Rebuilt and reinstalled the rear end last weekend. New trac-pak and 3.73 gears and a new bearing kit.
Will put new rotors on this coming weekend. Put on bbk upper and lower control arms and new kyb's all around from late model restoration. Have a tko-500 to go in and a new shifter as well. Bought a used dual friction center force clutch to go in also.
The motor and kit are from ford strokers, a diy kit, we are actually building two motors at once as the other guy has the red motor in the background of one of the pictures, it's also his shop.
I don't expect to have this thing running until around Feb. only get a few hours per weekend to work on it.
