Actron remote starter hook up ?
Methodical
1,172
Clinton, MD
I have an Actron remote starter switch - the kind used to turn the motor over while adjusting valves etc. - not the remote starter via an alarm system. I did a search but keep getting info on the alarm remote starter.
Can anyone school me on how to hook it up?
Thanks
  • Sponsors(?)
TGgnatsum49
14
Pensacola,Fl
Thanks
I cant but i can ask you how much you paid and wehre ya got it.
HISSIN50
SN Certified Technician
27
129
Yep. You normally are jumping battery power friom the solenoid and the solenoid-trigger (just because they are right next to eachother).
FWIW, you should be able to jump battery power into the *starter relay* output (normally open) terminal. This relay is in the underhood fusebox (it's a slave to the piggyback solenoid). This is a lot easier to access.
The starter interlock wire is white/pink leading up to the fusebox starter relay as I recall. I cannot remember the color out of the relay's output wire however.
Thread starter Similar threads Forum Replies Date
Nutty 5.o For Sale Actron CP9015 Ford Code scanner in Southeastern Pa for Sale $25 Engine and Power Adder 2
des89stang SOLD Actron Code Scanner For Obd 1 Ford Vehicles. 81-95 Other Classifieds 2
tracyballard Is the Actron CP9580 the best code scanner available? SN95 4.6L Mustang Tech 5
Black05Pony Actron CP9135 issue... 2005 - 2009 Specific Tech 1
M Actron or Autoxray? Fox 5.0 Mustang Tech 3
ShiftTheDrift Actron Ford Module? 1994 - 1995 Specific Tech 5
R Key remote mod 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
T Unable to program remote 2005 - 2014 S-197 Mustang -General/Talk- 2
fiftyslost Electrical Garage door remote 2005 - 2009 Specific Tech 1
V 2010 GT 5-speed remote shifter 2010 - 2014 Specific Tech 1
P 2012 V6 remote key problems 2005 - 2014 S-197 Mustang -General/Talk- 0
H 99 GT - Horn on Steering Wheel not working BUT works with Keyless Remote Access button 1996 - 2004 SN95 Mustang -General/Talk- 1
H Horn on steering wheel not working on 99 GT BUT works with Keyless Remote Access button 1996 - 2004 SN95 Mustang -General/Talk- 1
shufixer Remote start on 2000 GT issues after instal, anti theft kicked in car died 1996 - 2004 SN95 Mustang -General/Talk- 4
acpowell 1995 remote not working 1994 - 1995 Specific Tech 0
larrym1961 Remote Tfi: Engine Shuts Off Code 14 Fox 5.0 Mustang Tech 8
larrym1961 Best Place To Hook Up A Remote Starter? Fox 5.0 Mustang Tech 4
larrym1961 Pip Code 14 After Remote Tfi Install Fox 5.0 Mustang Tech 1
B 2001 Remote Door Lock 1996 - 2004 SN95 Mustang -General/Talk- 0
jruppert 3650 Remote Shifter Location Mod 2005 - 2009 Specific Tech 0
El_Trippy_Boricua Remote Lock SN95 V6 Mustang Tech 0
M Program Remote 1996 - 2004 SN95 Mustang -General/Talk- 1
Sogogi110 Remote Start Issues. 2015+ (S550) Mustang -General/Talk 3
S Need Remote Tank Power Steering Pump Advise Fox 5.0 Mustang Tech 1
M Email/remote Tune Worth It? SN95 4.6L Mustang Tech 4
autoxdriver Help W/ Remote Programing 1996 - 2004 SN95 Mustang -General/Talk- 1
candphall Interior and Upholstery Remote Mirror Help 1965 - 1973 Classic Mustangs -General/Talk- 8
S Need Help W/ 1968 Mustang Remote Control Side Mirror, Driver Side 1965 - 1973 Classic Mustangs -General/Talk- 2
T Ignition Lock Cylinder Matching The Door Locks. 1994 - 1995 Specific Tech 6
D 96 Stang V6 Project Keyless Remote Problem The Welcome Wagon 0
xShMaCkBoYx Stolen Remote Entry SN95 4.6L Mustang Tech 2
N Expired Passport 9500 Ci Remote Radar/laser Laser Shifter Other Classifieds 0
whammo77 Remote Hood Latch? Classic Mustang Specific Tech 3
68GT500KR_Vert Expired Cnc Dual Master Cylinder & Remote Reservoirs Brake Assembly Wheels/Tires/Brakes 0
S Remote Keyless Entry Programming Not Working 1996 - 2004 SN95 Mustang -General/Talk- 2
Nightfire Best Remote Tuner? 1996 - 2004 SN95 Mustang -General/Talk- 5
John Dirks Jr Viper Alarm And Remote Entry 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
A In Need Of An Excellent Remote Tuner For Full 5.0 Coyote Build! Pls Help 2005 - 2014 S-197 Mustang -General/Talk- 0
96 mystic 96 Remote Keless Entry Module SN95 4.6L Mustang Tech 1
StangVertGT Best "safe" remote start for manual car SN95 4.6L Mustang Tech 3
StangVertGT Expired Best "remote car starter" for manual transmission car Other Classifieds 1
Andy golip Remote car starter problems causing my car not to start at all SN95 V6 Mustang Tech 1
7-UP BILL Remote trunk release 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Jeremiah Emerson Electrical Keyless entry key remote does nothing, but gives off RF signal. SN95 V6 Mustang Tech 4
ratio411 I Have A 94-95 Remote Tfi Distributor. How To Install It On A Fox? Fox 5.0 Mustang Tech 1
DudeHuH Remote Start In 2012 Base 2010 - 2014 Specific Tech 9
J Remote start SN95 4.6L Mustang Tech 4
Bullitt347 Remote mount kit for engine oil filter Engine and Power Adder 0
Three50won Pro-M/Pro-Flow Remote Optimizer... 1994 - 1995 Specific Tech 7
TrophyHead Stock fuel rails and remote fuel pressure regulator Fox 5.0 Mustang Tech 4
