Can you guys with the Trick Flow setups post your power figures or track times? I'm seriously debating combos here and leaning toward the Twisted Wedge heads, Stage 1 cam, Track Heat intake. It will be going on with long tubes, a Prochamber and dumps (to replace my o/r h and Flows). It has a 65mm TB and a 76mm MAF. I have a T-5 and 4.10's. Car weighs 3420 (with me).
Trick Flow advertises 360hp/380ft-lbs. with that kit.
I'm wondering if any of you have similar combos and what numbers you run or make.
Thanks all.
Thanks all.
