Any difference between 94-04 Cobra and Mach 1 front calipers
Slow5.0
2,554
Portland, OR
Two years ago i swap stock front calipers for 99+ PBRs
Now i wanna swap once again for Cobra calipers/rotors
I was wandering is there any difference between 94-95, 96-98, 99/01, 03-04 Cobra and 03-4 Mach 1 front calipers
I already have 99+ lines and banjo bolts but do i need difrent one with this setup
THe 99+ gt pbr calipers have the 40+mm bore. Those are not the same as the mach 1/cobra calipers. But yea:
http://www.maximummotorsports.com/ in the brake hoses section (read the captions for the brake hoses) they have a brakedown of which banjo bolts you will need. Depending on if your 99+ calipers coarse or fine banjo bolts, depending on the year you could have either coarse or fine. But most of the cobra calipers you purchase will require coarse banjo bolts. WHerever you buy...just make sure you ask if you get just the calipers.
The piston diameter got 2mm larger. Big deal....I bet you can't tell the stoping power difference. The major difference is the style. They are still the same calipers.
