Any help with Microsquirt tuning would be very much appreciated
.csv means you did a high speed log, that's not the same as a datalog.
High speed and composition logs are .csv meant for troubleshooting
The datalogs are done from the top of the page should save as .msl files
Tunes save as ..msq
Sorry guys, ran into some fuel tank issues....
I've attached (I hope) a few data logs and tunes. Please let me know your thoughts...
  • 2020-01-03_15.26.29.msl
  • 2020-01-03_15.27.59.msl
  • 2020-01-03_15.30.58.msl
  • 2020-01-03_15.34.20.msl
  • Current Tune.msq
My fuel tank “issues”... That :poo: sitting on the garbage can is what came out of the filter.
Inside of the tank was filthy and the baffle was completely broken.
Have i helped you in the past? Or did you grab one of the tunes found on the forum?
I pulled one off the forum that looked close to what I had. Tried for over a month to auto tune, but couldn’t get it close. I’ve been auto tuning that tune that I uploaded, it seems to be getting better. Still a few rough spots though.
You will see the changes, it needs work still.
Alot of getting idle just right is in the settings.... you may have to take a turn out of the TB to get it to idle where you want it to hot.
Try the tune I posted first.
OMG, what a fricken difference. Pulled much harder than before!!! Idles ok and doesn't have much of a surge anymore.
I'm sure there's more work that needs to be done, but I cant believe how much better it ran.
Thank you SO much for your help!
  • 2020-01-04_14.55.07.msl
