AOD 1-2
pdiddy1
ohio
Looking for help - problem with AOD
I have swapped c4 for AOD in my 66 mustang....here is the issue. I have no 1st gear when in "D" or "OD", always starts in 2nd. Everything else works. I have 1st when i put shifter in "1", if i bump the shifter to "D" it upshift immediately to 2nd without pressing the gas pedal. Anyone has any ideas to solve that problem?
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
14,920
4,712
193
polk county florida
I moved this to classic tech cause I'm sure some members here have done this swap and I figured you have a carb, most of us in the fox forums can't remember or have never seen a carb unless it was on our lawnmower.
I do have to ask, do you have the tv cable hooked up?
pdiddy1
ohio
I have lokar TV cable....OPSI in "P" and "N" and 90PSI at WOT. Also I have the Holley arm installed so ratio 1:1 between TV cable and Throttle.
