Anyone running the B&M differential cover with the carrier supports? I've got a clearance issue with the stock away bar smacking the left lower side. Is there a aftermarket sway bar I should look into? Or just grind some of the cover off?
Well seeing I'm in the dark on this one, and for anyone else that does the same as I did and incurs the same problem.. The eibach sway bar clears it (barely).
