STEP 5. Check that the shifter is in
the Neutral position. The transmission
should also be in the Neutral position.
With both the shifter and the
transmission in the Neutral position,
loosen the adjusting nut on the transmission shift lever at the front end
of the shifter cable. Pull forward
lightly on the cable to take up the free
play in the cable and then tighten the
nut while still maintaining tension on
the cable. Check that the shifter will
move to all the gear position without
having to use excessive force. (See
the Operation section at the end of
these instructions.) Particularly
check that the transmission lever
moves to the Reverse position when
the shifter is moved from Park to
Reverse. If it does not, recheck the
cable adjustment procedure above.
If your shifter cable is well used it
may have developed too much free
play to work with this shifter. In that
case you will need to replace it with
a new Ford cable.
STEP 6. Turn the ignition key to the
unlocked position, one notch clockwise
from the locked position, and
put the shifter into Park position before
installing the interlock cable. Cut
the end off of the plastic interlock
cable support as shown in figure 2.
Slip the end of the center wire of the
interlock cable into the slot in the interlock
bell crank. Attach the cable
housing to the base of the shifter
using the supplied socket head 10-
24 x 1/2 screw and nut plate. See
figure 2. Do not tighten the screw all
the way, leave it loose enough so that
cable will slide back and forth in the
slot.
