There's something wrong with that car. It has a terrible surge. If you listen to him rev it it sounds "smooth". Then when he stops revving it and lets it come down in RPM you can hear the computer catch it and hold the RPM at about 1100 for a second. It's still running smooth. Then the computer slowly drops the RPM (like it supposed to) and it still runs smooth until it hits idle at which point it starts surging after a couple of seconds right at the end of the video. If the surge was a function of the cam the surge would get progressively more pronounced as the RPM fell but it doesn't. It comes on all at once when it idles. I suspect his idle is really too low.
Mine idles like that but without the surge.
That car also sounds nastier than most because of his exhaust system. He probably has long tubes with straight pipes. You can see the car pop out the exhaust at one point and that usually means there's no mufflers under there.
Your actual cam timing will also make a difference in idle too. When I put mine in I spoke to Thumper460 first and he told me how to set it up for the most streetable power range and a great sounding idle. I get nothing but compliments every time I take it out.
