Backfire& Bogging
twohawks777@cox
108
15
28
I am having backfiring and bogging issues. It happens when the car is up to temperature. It is bogging in the mid-range around third gear. It's very responsive at WOT but backfires sometimes. Can anyone please figure out what's happing in this tune?
  • CurrentTune[1].msq
  • 2021-09-05_07.45.46.msl
Can you elaborate on the issue? when does it happen? on tip in? after a gear change?
I see some lean spots at part throttle in the mid range, other than that the O2 appears to have a laggy response.
It is most definitely lean by more than a whole point on AFR. can you verify fuel pressure
It happens when I launch it hard sometimes. I get a backfire around 4500 rpm. I notice when I drive it around town at low speeds shifting I am hearing and feeling light popping. Bogging It's not necessarily consistent. Fuel pressure was at 50psi. I turned in down to 42psi with vac off.
I need to do another data log. I found that a rubber cap off the t -body was cracked and letting some Unmetered air In the system. Vacuum leak. Let me do another log and see if that fixed anything.
When you inquired about the fuel pressure I noticed it was a bit high so I thought. The log was was with it at 50 psi. I will try a new log at 42psi and see if that improves anything tomorrow.
I drove it around today. It did not appear to bog as much. I did not notice the same backfiring but some. Please check and see if it looks better. My laptop disconnected a couple of times but managed to get an assortment of data logs.
  • CurrentTune.msq
  • 2021-09-07_17.40.27.mlg
  • 2021-09-07_17.49.02.mlg
  • 2021-09-07_17.52.15.mlg
If you backed the fuel pressure down then thats the issue. dropping the pressure from 50 down to 42 psi makes the injector act smaller and requires a fuel trim.
  • CurrentTune.msq
