my battery won't hold a charge. i got it tested and said it was fine. could it be grounded? any ideas?
5l5 could it be though that the alternators not charging the battery there fore when the car is jumped and running its running directly off the battery and jus sucking it dry? i had this issue on my mothers lexus this is why i chimed in but feel free to let me no if i am totally off
Get a DMM that measures AMPs in DC current. Disconnect one lead of the battery and wire it in series. Tell us how many amps you are drawing with the car shut down.
Once a battery is drained, it doesn't hold a charge as well and is easier to drain down. If you have to constantly jump a battery...it's junk and should be replaced. However, determine if you have a parasitic drain on your car first before buying a new one
autozone tested the battery, guy actually tested it twice.
sunvisor lamps dont stay on. i doubt it would be those it just started happening two days ago and the battery drains with minutes
