Bbk Cold Air Intake
  • Sponsors(?)
2000xp8
SN Certified Technician
Aug 8, 2003
6,877
1,028
194
NJ
You don't give many details, is it a fender well kit or an open filter in the engine bay?
Stock mass air meter? Some aftermarket ones don't like cold air intakes.
Did you try reverting it back to stock?
Did you oil the hell out of it? Sometimes the oil gets on the mass air meter.
Putting your car info and mods in your signature helps us, help you.
510notch
26
Bay area California
Sorry about that, from what i know it is still a stock air meter there are no mods other than the cai, it is a fender well kit i have not tried going back to stock but i will be cleaning the mass air meter today and then i will install my stock back if it doesnt work.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,089
9,226
224
Massachusetts
To be honest, i threw my BBK CAI in the trash and put the stock one back on. It began to rust up on the surface after a while and i got sick of polishing it. Also, it got VERY hot after a good drive.
Stock airbox and drop in K&N is really all you need. The BBK kit does look prettier but in terms of a horsepower gain, the stock airbox is decent
Reactions: 2000xp8
mikestang63
Aug 27, 2012
9,901
6,685
204
In the garage
No problems with mine. My guess is oil from the filter got on the MAF or the MAF needs to be clocked as the airflow has changed.Some aftermarket MAF's are for stock airbox vs. CAI
Reactions: 510notch
510notch
26
Bay area California
Hey guys so i finally got my car back from the shop so i havent had a chance to clean my MAF, but now i have other issues, i took my car to have them install my bbk shorty headers also had them install new valve covers and new mounts on motor and tranny, my problem now is that the car is idleing too high and feels like the engine is heating up way too quick, i also had smoke coming from the engine on driver side i think this might be from the new covers and headers, but what about the rest of the new stuff that is now wrong with it, another thing is that now my oil meter inside the car reads low i checked all fluids and they are ok any help would be appreciated thanks guys.oh and it definetly still feels sluggish. oh another thing is that when i go in 3rd gear i feel the tranny jerk more than before.
2000xp8
Aug 8, 2003
6,877
1,028
194
NJ
The header gaskets will smoke and smell for a short while.
The oil gauge is crapshoot, a better gauge is the only real solution to know if you have an oil pressure issue.
The temp goes up too quick or too high?
510notch
26
Bay area California
my temp gauge says normal but i feel like my engine is getting hot way too quick compared to before, my CAI also gets real hot is this normal?
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,312
374
134
Between the Red and Rio
1. I don't belive you have a maf issue.
a. If the maf was dirty or broken the car wouldn't idle.
b. While yes the filters come pre-oiled it's been sitting awhile before it gets to you so it's not dripping wet like after one re-oils it at home.
c. Unplug the maf and try and start the car. If it won't start or it starts for a second and dies your maf is working.
2. Heat and high idle. I bet you have a vacuum leak at either the header gasket or valve cover.
3. CAI and sluggish. It could be that maybe you were expecting more out of it. As someone else mentioned the main purpose they serve are for cosmetic purposes. The manufacture hp claims are bogus. When K&N filters hit the market they claimed a 25 horse gain from their drop in the box pannel filter. I guess the cat's outta the bag, now the commercials claim they are good for the environment.
Oh and the oil pressure gauge- an old oem one will wander all over the place.
510notch
26
Bay area California
3. CAI and sluggish. It could be that maybe you were expecting more out of it. As someone else mentioned the main purpose they serve are for cosmetic purposes. They manufacture hp claims are bogus. When K&N filters hit the market they claimed a 25 horse gain from their drop in the box pannel filter. I guess the cat's outta the bag, now the commercials claim they are good for the environment.
ugh damm i was also thinking that it might be a vacuum leak in those two places, i will check it before i drive it back to the shop that did the work so that if there is a leak they cant just blow me off and say everything is fine. i told them to check for vacuum leaks prior to me picking it up i guess they didnt check
Reactions: 90lxwhite
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,782
2,409
194
Illinois
The headers aren't causing a vac leak. Go through the surging/high idle check list that's posted here in the Tech forum. My guess is it's a sensor. Run the codes! And post back.
Reactions: 510notch
7991LXnSHO
Now I want a 10 year badge
Sep 1, 2010
2,593
425
124
Kearney, NE
I have been thinking about your concern that the chrome steel will transfer enough heat to be a problem, especially at idle, and what to do if the chrome rusts. Then I saw the spray on rubber coating infomercial!
Flex Seal it in any color! That way you still have the smooth interior flow with a layer of insulation in any color (out of nine) you want!
Flex Seal | Liquid Rubber Spray Sealant Stop Leaks
And you get to wear a cheesy grin!
90lxwhite
5 Year Member
Aug 25, 2011
3,312
374
134
Nor the valve covers? Headers and valvecovers were the last things messed with before the high idle.
A5literMan
5 Year Member
Jul 30, 2011
4,782
2,409
194
Illinois
There is no vacuum on the exhaust side. It's most likely something got moved,damaged,etc like the tps sensor,MAF,the salt and pepper shakers,a hose/vac line,etc.
Reactions: 90lxwhite and 89oem
Thread starter Similar threads Forum Replies Date
BlakeusMaximus For Sale BBK cold air intake for sale. 86-93. $150 Engine and Power Adder 1
M Is This The Correct Bbk Cold Air Intake Fox 5.0 Mustang Tech 7
cutecrimnal143 Tune Help With Mustang Gt And Color 1996 - 2004 SN95 Mustang -General/Talk- 4
sTTang Expired Nib Bbk Cold Air Intake Engine and Power Adder 0
Blown88_GT SOLD 73mm c&l, Walboro 190lph pump, BBK cold air, 24lb injectors Engine and Power Adder 3
1993whtstang Bbk Mass Air Flow Sensor For 19 Lb Injectors And Cold Air Intake Engine and Power Adder 1
tobynt FS: BBK 96-04 Mustang GT CAI Cold Air Intake System (Chrome) 1718 Engine and Power Adder Parts 2
MeanMussy FS: BBK Cold Air Intake (P/N 1557) Engine and Power Adder 1
A BBK Cold Air Intake 96-04 4.6 GT Engine and Power Adder Parts 1
MRaburn 2011 Mustang 3.7L V6 BBK Cold Air Intake Install 2010 - 2014 Specific Tech 0
MRaburn 2011 Mustang 3.7L V6 BBK Cold Air Intake Install StangNet Site News 0
J Cold air intake - BBK 1712 or K&N 57-2511? 1994 - 1995 Specific Tech 10
D Correct BBK cold air intake system? SN95 V6 Mustang Tech 4
A PI Intake Manifold, 80mm MAF, Injectors, BBK Cold Air Intake Engine and Power Adder Parts 7
A F/S BBK COLD AIR INDUCTION $130.00 Engine and Power Adder Parts 0
Q BBK Cold Air Intake 1996 - 2004 SN95 Mustang -General/Talk- 9
M BBK Cold Air Intake Fox 5.0 Mustang Tech 2
Manewaymja2 76mm MAF Meter on a BBK Cold Air Intake. Is this going to work??? Fox 5.0 Mustang Tech 2
R BBK Cold Air help Fox 5.0 Mustang Tech 3
N BBK Cold Air Intake Help Fox 5.0 Mustang Tech 4
E BBK Cold Air Intake and Throttle Body 2005 - 2009 Specific Tech 4
J BBK Cold Air Intake SN95 4.6L Mustang Tech 8
N c and l and bbk cold air induction Fox 5.0 Mustang Tech 5
dave96stang BBK cold air kit and throttle body 2005 - 2009 Specific Tech 14
V BBK Cold Air Induction SVT Tech Forum 1
V BBK Cold Air Induction Install for Cobra SN95 4.6L Mustang Tech 2
jrs307 BBK Cold Air Kit? 2005 - 2009 Specific Tech 1
G BBK IN the fender Cold air!!! Fox 5.0 Mustang Tech 5
grantur01 Is there a rubber plug on a BBK Cold Air Induction??? SN95 4.6L Mustang Tech 5
rice slayer' bbk cold air intake...hp?? SN95 4.6L Mustang Tech 2
satter_m BBK Cold-Air Fenderwall Mount Question SN95 4.6L Mustang Tech 3
92Stang302 Which Side Fendor or Reg : bbk cold air? Fox 5.0 Mustang Tech 2
5.0CRAZY Question for those with BBK cold air kit... Fox 5.0 Mustang Tech 14
5.0CRAZY Question for anyone with BBK cold air kit... Fox 5.0 Mustang Tech 1
R Bbk Cold Air Kit SN95 4.6L Mustang Tech 7
Mustang5L5 BBK cold air intake with Speed Density Fox 5.0 Mustang Tech 6
patboy MAF, will it fit in BBK cold tube? Fox 5.0 Mustang Tech 3
H 93 302 BBK Header Gasket Leak 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
fitnage Added BBK Long tube/BBK no cat X/Pypes Cat - weird sounds 1996 - 2004 SN95 Mustang -General/Talk- 9
D 98GT BBK UD installed without harmonic!! SN95 4.6L Mustang Tech 0
A Installing BBK SSI INTAKE 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
N For Sale 76mm bbk maf for #19 injectors Engine and Power Adder 0
C 2013 Mustang GT Headers 2005 - 2014 S-197 Mustang -General/Talk- 0
ebowie 351w with Trick Flow 11r heads with BBK tuned headers in 1995 SN95GT fit ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
79 Fox Fox Opinions on BBK Varitune cat back? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
5 New guy The Welcome Wagon 4
A BBK catalytic convers for shorty headers done 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R Exhaust set up advice. O\R H pipe or high flow cat H pipe? 2005 - 2014 Specific V6 Tech 2
Mstng93SSP SOLD BBK 70 MM Throttle Body SOLD! Engine and Power Adder Parts 0
74stang2togo For Sale BBK shorty headers for 302 Other Classifieds 0
