When I say reliability I'm only talking about the ignition components. Quality MSD, Jacobs, Mallory, Accel, etc components will last longer than your Auto Zone, Advanced, Orielly, etc remanufactured parts. Now some will argue that the quality isn't the best on aftermarket parts when compared to stock motorcraft/ford parts. You won't really see gains in HP, fuel economy, driveability by upgrading unless the parts that are on your car now are worn and causing the engine to run less the optimal. Once you start upgrading components and need a more control over the ignition system that is where the aftermarket parts will make the difference. If you plan on running a supercharger, turbo, or nitrous, you will want to be able to retard the spark based on boost. This can be done with the aftermarket parts with boost controls.
