not a chance in hell... end of story! you can do all the math you want till your blue in the face. you'll never make 700hp on a single 255 on any power adder car.It's enough to feed 700 supercharged crank HP.
it may work... but how much is your motor worth to you at that point?Well... unless it's backed up by a BAP or something that can bump up voltage/volume.
this is true... the cobra and lightning owners have the options to run a 3rd pump these days. and im really not a fan. at that point id go to a fuel cell and run a big magnafuel externalI don't consider that any more risky than having a single pump fail in a two pump system. Either scenario would be a disaster during a pump failure.
what you have to understand is that it isnt simply a matter of the intank pump. the lines and rails are small and thus restrictive. also, it depends on the fuel pressure. the higher the fuel pressure the less the pumps flow. so in a forced induction application if you are pushing your FP to 100 psi (which i wouldnt recommend, but in a boosted application you at least need to raise the FP 1 psi for every lb of boost to overcome the pressure differential), it is entirely possible for the 255 to be flowing less than a 155 would at 35 psi. it is an inverse relationship.
TroofsAlso need to factor in the power a blower is using... If its making 100hp it's prob using another 60-70 just spinning it.
