Best transmission for 98 cobra?
CobraSwappedGT
Tyler, tx
I have a 2003 gt swapped with a 98 cobra. Currently the transmission is cracked and I’m just wondering what trans would be best to replace it and if I could get a stronger trans, what would properly bolt up to the 98 cobra and the 03 gt?
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,096
9,229
224
Massachusetts
Since it’s a swap car need more info. Was the t-45 from the cobra used, or the t-3650 from the 03 GT used?
silversmith82
67
Most likely its a stick. A rebuilt 3650 is what I have done and would do again and will do again if/when the t45 in my 2000 goes. Get ahold of Stan at Pro Force Performance in Atlanta. That will ensure all the fixes are done and you can choose the .68 or .62 overdrive.
Had a fully fixed stock rebuilt 3650 in my 98GT and that was legit the smoothest best shifting trans I have ever had save maybe the low mileage original T-5 in my old 95 Cobra. 3650 gears are beefy and with the fixes done the weak point becomes the 10 spline input which is good for about 500ft lbs. Get a 26 spline shaft and they are good for even more.
Thread starter Similar threads Forum Replies Date
2fast4u770 Best manual transmission 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
R Best transmission oil? 1996 - 2004 SN95 Mustang -General/Talk- 1
Killa What Is Best Transmission Cooler For 4r70w SN95 4.6L Mustang Tech 2
untohim Best 5.0 Manual Transmission? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
StangVertGT Expired Best "remote car starter" for manual transmission car Other Classifieds 1
K Best Way To Store An Automatic Transmission? Classic Mustang Specific Tech 1
M Best Manual Transmission for these Mods Fox 5.0 Mustang Tech 18
R best place to mount a transmission cooler SN95 4.6L Mustang Tech 3
Alex46 Best manual Transmission? SN95 4.6L Mustang Tech 10
8 T-5 transmission fluid whats best Fox 5.0 Mustang Tech 9
squares98 Best prices on t-56 transmissions? 1996 - 2004 SN95 Mustang -General/Talk- 0
enyawix Best Manual Transmission Fluid? Fox 5.0 Mustang Tech 5
J What kind of ATF is best for a stock manual transmission? 1994 - 1995 Specific Tech 16
2 What is the best transmission for the 05? 2005 - 2014 S-197 Mustang -General/Talk- 18
281pony Best/Specific Transmission Fluid? Fox 5.0 Mustang Tech 5
R Best RWL Tires For a 1971 Mach 1 that will be driven? 1965 - 1973 Classic Mustangs -General/Talk- 2
7991LXnSHO Best torque boxes currently? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
D Best upgrades for fuel system? 00 GT 4.6 2v Digital Self-tuning Forum 1
K Best way to clean 4.6L DOHC upper and lower intake manifolds? 1996 - 2004 SN95 Mustang -General/Talk- 3
R Best clutch cable replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
B “Best” Budget Aftermarket Flywheel. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
Saine65 Best Efi Route 1965 - 1973 Classic Mustangs -General/Talk- 7
E Best tires for 88 Foxbody GT? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
L Exhaust Best Fox exhaust Fox 5.0 Mustang Tech 4
R The best page The Welcome Wagon 1
Blucifer99 Pop and bang tunes...... best and safest way to make them? Digital Self-tuning Forum 4
95TT347Cobra BEST SWAP OPTIONS! 05 GT 4.6 3v (Threw Rod), I have a 4.6L 2v out of an 04 GT and 4V in A mark. Suggestion? 2005 - 2009 Specific Tech 2
M What intake is best for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
R Best loudest exhaust for 89 gt? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
D 1999 mustang gt best direction to go?. 1996 - 2004 SN95 Mustang -General/Talk- 5
MrPerfect2 Best antifreeze for cooling properties 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
1989FoxFan Interior and Upholstery Best Brand of Top for First Time 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
Schnelly Best 1/4 Mile times 2005 - 2014 S-197 Mustang -General/Talk- 1
S Best 99-04 Mustang GT clutch kit replacement? SN95 4.6L Mustang Tech 1
0 Drivetrain Best Clutch and Flywheel Combo? SN95 4.6L Mustang Tech 4
D Whats the best intake for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Noobz347 Best Commercial on the INterwebz - S550 Widebody 2015+ (S550) Mustang -General/Talk 0
S Best dual plane intake for small block Windsor Other Auto Tech 19
P Best coil packs for a 96 mystic cobra SN95 4.6L Mustang Tech 18
Woody3882 Best location for exhaust cut outs 1965 - 1973 Classic Mustangs -General/Talk- 1
silverlx50 Engine What is the best way to lift lower intake off? Fox 5.0 Mustang Tech 7
MrPerfect2 Which brand gears and install kit has best quality parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
K Fox Finding the best head gasket for semi-built 302 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
B Best quality toe pans for 69-70? 1965 - 1973 Classic Mustangs -General/Talk- 3
B Needing help on the best way to tackle alot of sheet metal replacement 1965 - 1973 Classic Mustangs -General/Talk- 2
J Best cams for supercharged ‘06? 2005 - 2014 S-197 Mustang -General/Talk- 1
I Needed best 4.6 intake manifold for 97 GT SN95 4.6L Mustang Tech 5
Wayne Waldrep Exhaust manifold gaskets...the best 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
O Best Cams for Old Muscle car sound? 1996 - 2004 SN95 Mustang -General/Talk- 7
H Best quality reproduction sheetmetal 1965 - 1973 Classic Mustangs -General/Talk- 1
