Biggest injectors you can run on stock ecu?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,137
6,047
204
31
Hillsborough county
This is from experience playing with 351w engines and 76mm turbos.
you will find the edge of the turbo map before you reach 700hp. 3 separate builds all with a similar cheapie 76-78mm turbo after 25psi we just made more heat no extra power.
Reactions: TOOLOW91
  • Sponsors(?)
96pushrod
Advanced Member
May 15, 2018
817
496
73
28
Savannah
Thank you for the answer to my question. I might have to run a pimpxs ecu with tuning. Pro m sells 75lb with a calibrated mass air as well.
Oh gee I think I suggested that earlier . Then you won’t need the meter anymore either.
Definitely go with a stand-alone type of efi. Pimpxs is a great system and easy to setup and use. I’d recommend it.
As toolow said, the mass air meter can go in the trash if you go with a megasquirt based controller, as they run speed density
TOOLOW91
7,147
234
S.I.NY
Stock block 357w we have been 8.51 with a 78/75 billet precision . Goes to show you the difference in buying a better turbo makes . Also a bit bigger to of course
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,137
6,047
204
31
Hillsborough county
One of the builds that got good traction went a best of 9.2 at 143... car needed a driver mod, he was painfully slow rowing the tko600
TOOLOW91
7,147
234
S.I.NY
That’s still some mph !!!
kiddiccarus
The first widely accepted Tranny
1,089
561
133
30 Mins from a Ragged GT
www.angelfire.com
Are you able to run the holley ev1 66lb injectors on a stock 1989 mustang ecu. Currently running 42lb injectors changing over to a turbo setup going for 800rwhp. What I understand the 42lbs are only good for 550rwhp. Ecu is all factory just running a 6al box with btm and a fmu with a 255 in tank.
guess your not familiar with the project stock bottom end car. He's making 915whp with a Chinese turbo lmao. Motors been together for 4years. Maybe back in the 80s they would split at 500hp but nowadays a few guys are making this hp level.
UMMMMMMM Wasnt YOUR Mustang, Block and well Everything Stock you have made in the 80's?
Reactions: LILCBRA
TheLeech405
9
Oklahoma City
Ignore any other information on here. The stock fox eec-iv computer will let you input an injector slope up to 112lbs for the high and low slope. Deka 80s, a very common injector, and those I use on one of my personal cars right now, have a low slope that pushes the boundaries of that 112 limit. However, you can easily apply scaling factors to other aspects of the tune to take it even higher. I have personally tuned a truck with 220 lb injectors on e85 using an EEC-IV with a quarterhorse chip. You'll be fine with 80 lb injectors in the hands of a competent tuner using a quarterhorse chip on a stock computer. Those injectors will get you to your power goal if you've got the pump, feed line, and rails to support the flow.
Shoot me a message if you're interested in having me tune this for you free of charge (assuming you pickup a quarterhorse chip and binary editor software). You will need to remove the BTM and FMU from the equation though. You can probably sell that stuff off for about the price of the quarterhorse chip. There's somebody on the Binary Editor FB group right now selling a package deal for $350 for the software license dongle and the quarterhorse chip. Still in box with sticker and everything.
Reactions: Cheapskate207
TheLeech405
9
Oklahoma City
In the same breath, though, I wouldn't recommend pushing over about 18-20 pounds of boost using a stock computer on a stock block due to the lack of knock sensors. You're going to be pushing the block way past the extremes at 30 pounds and I wouldn't feel good about doing that without knock sensors and wideband-fed short term fuel trims.
2000xp8
SN Certified Technician
Aug 8, 2003
6,877
1,028
194
NJ
Any "competent" tuner would run from this project, because when it blows up, so does your reputation.
The OP has no clue what he's doing and neither does anyone that says go ahead use 80s and I'll tune it.
Then a post later admits it's extreme.
You guys should work together on this project, do a Facebook live dyno video, it will be epic.
I don't have an account but I'll sign up to see the fireworks.
It's a stock block, nothing changes that.
Regardless of how it's tuned, the tuner, the boost, the outcome will still be the same...
TheLeech405
9
Oklahoma City
I'm
I'm not going to argue with you. You know literally nothing of my work and competency when it comes to these cars. I'm speaking from experience when I say the stock computer with 100% certainty can and will work for this combo. I'm not telling the guy he should try to push a stock block to 800+ horsepower. I'm trying to explain that the stock computer will not be the reason for the car blowing up. Don't know how many turbo combos you've tuned, but I feel pretty good about my own capabilities. Again from EXPERIENCE. Not from idle chatter coming across forums and facebook feeds.The car in my garage right now has a 76mm turbo on a HCI 347 stock block with 80 lb Deka injectors. A9L computer, a QuarterHorse, and a wideband. Running off the gate at 12 psi. Sure sounds a whole lot like the combo the OP is wanting to put together. Just a little less boost. It's dialed in and drives like a dream. Super strong. Do what you want with your cars and money, but don't bring your negativity into these public forums. It's unnecessary and childish. I sure as hell hope you also have several thousand hours behind the keyboard tuning these cars if you're going to bring this kind of cocky bull:poo: into the thread like you know better than the rest of us. I'm done on this one. But again, Op, let me know if you'd like some help. That's what these forums are for.
2000xp8
Aug 8, 2003
6,877
1,028
194
NJ
Interesting, you mysteriously show up on the forum, start with "ignore any other information here", then move on to self promotion, followed by bad advice and accuse someone else of bringing cocky bull to thread?
If you even took the time to read all the posts you'd see that most of us think the computer is the least of his problems.
He's trying to run a stock block with mediocre parts and a boost a pump to 800rwhp on a budget.
I guess the good news is, he found a competent tuner that can tune out the wrong parts...
Monkeybutt2000
282
208
53
48
Lafayette,IN
Interesting. Once again,the OP on this post is gone....never to be heard from again. As far as TheLeech, I've seen your tuning videos on Youtube. I understand you were "called out" on here,but your replies could've been less pompous. All you had to do was explain your background and maybe throw up a video or two.Of course these long term members are gonna give you some grief.
General karthief
Mod Dude
Aug 25, 2016
16,921
5,411
193
polk county florida
I watched a couple of his videos too, the one about moving the air temp sensor was interesting but I found it inconclusive, maybe if I understood tuning talk better?
He seemed to know the 'tuning talk'.
Olivethefet
Slap me as well as point and laugh
May 17, 2018
1,705
1,117
123
39
Enterprise AL
I think they just aren't built that tough. You get all that mass rotating and pressure from boost or high compression and then the block splits. Makes since to me.
Foxslider
im not that much of a idiot
Oct 25, 2019
250
64
38
33
Houston, TX
Thats what i was thinking, but most of the boost should be in the cylinder bore, but maybe the blow by adds up creates.... ok its the tensile strength of the middle of block. The ignition of the gas causes so much more force (since each side is oulling away from middle, that it just splits in the middle and pulls/cracks apart. I think. Lol.
Thread starter Similar threads Forum Replies Date
Prerunner5.0 94 GT biggest rear tire on 18x9 wheel? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
B Fox Just picked up a sick set of cobra rims the rears are 17x9 and the fronts are 17x8 whats the biggest set of tires i can put on there guys 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
D My biggest build yet. 1974 - 1978 Mustang II Talk & Tech 48
6 Biggest rear tire stock height 1966 Mustang??? 1965 - 1973 Classic Mustangs -General/Talk- 0
T Biggest tires i can go on a 1993 gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
8 Biggest tire i can fit on my 83 gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
FastDriver Stupid question about the biggest 5.0 restriction 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
B 2001 SVT Cobra Biggest Tire Size SVT Tech Forum 6
Onesick99GT 1999 Mustang Gt Biggest Tires She Can Fit SN95 4.6L Mustang Tech 0
B Wheels-Tires 88 GT- Biggest tire size Fox 5.0 Mustang Tech 8
9 Drivetrain Biggest Gear Ratio For 95 Mustang? (found 4.56) SN95 V6 Mustang Tech 5
H Wheels-Tires Biggest Size? Fox 5.0 Mustang Tech 2
T 18"tire Size.what's The Biggest Your You Fit? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
S Biggest Sized Tire On These Rims 2010 - 2014 Specific Tech 2
Detroiit Biggest Tire Size On Fox Body 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
MBGT02 Biggest Tire For 2011? 2010 - 2014 Specific Tech 0
ADRENLN Tire sizes whats the biggest? 1996 - 2004 SN95 Mustang -General/Talk- 14
malice9005 Biggest tire to fit on 15 inch wheel Fox 5.0 Mustang Tech 12
BarefootPainter Whats the biggest cam a stock 5.0 can hold help Fox 5.0 Mustang Tech 27
Bonez8791 Biggest rear tire??? Fox 5.0 Mustang Tech 15
GLENN FORD Biggest Wheels Classic Mustang Specific Tech 2
bigsexxy422 whats the biggest cam in a stock 302 Fox 5.0 Mustang Tech 7
C Anyone know the widest/biggest front tire combo with UPR Kmember and coilovers?? Fox 5.0 Mustang Tech 9
I biggest tires on a 15" rim 94/95 1994 - 1995 Specific Tech 11
I 15/8 5.5bs and 15/7 4.75bs biggest tires please Fox 5.0 Mustang Tech 1
I biggest tires on 17x8 and 17x9 Fox 5.0 Mustang Tech 2
T biggest tires for 06 gt 2005 - 2014 S-197 Mustang -General/Talk- 3
N biggest 2v SN95 4.6L Mustang Tech 8
horseballz Biggest Tires For 68 Coupe? Classic Mustang Specific Tech 3
Rocket3005 Biggest Rear Tires 2005 - 2009 Specific Tech 7
D biggest headers 2005 - 2009 Specific Tech 3
T 15x8 with 4 1/2 backspace question (biggest tire?) Fox 5.0 Mustang Tech 3
0 whats the biggest rear tire that will fit on an 03 gt? SN95 4.6L Mustang Tech 7
f4fntm Northwest Foureye Barbecue 2009 - biggest ever Regional Forums and Event Information 3
stanglover0526 biggest tire for a 17x9? 1996 - 2004 SN95 Mustang -General/Talk- 4
R biggest/best tire size on 10 holes? Fox 5.0 Mustang Tech 6
deftsound What is the biggest tire that will fit on my 94 gt? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
TweekedGT Biggest tire and rim on a fox? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
1 Biggest motor put into a 94-95 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
thexrcist68 biggest adv. exhaust duration w/ stock style pistons Classic Mustang Specific Tech 0
Shiroelex Biggest slicks/rim combo? 1996 - 2004 SN95 Mustang -General/Talk- 1
Team Ford biggest cam 1996 - 2004 SN95 Mustang -General/Talk- 22
TwoToneHatch Biggest Tires On Pony Rims? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
9 Biggest M/T Street 1995 GT? 1994 - 1995 Specific Tech 10
9 Biggest Tire for a 95 on 15" rims??? 1994 - 1995 Specific Tech 0
daviszx3 biggest tires on 10 holes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
9 BIGGEST Wheels! 1994 - 1995 Specific Tech 16
I biggest tire to fit on a 17x8 rim 1994 - 1995 Specific Tech 3
mixedbreed02gt biggest tire size that will fit on an 18x9? SN95 4.6L Mustang Tech 1
P biggest Hyd. roller cam in 5.0 Fox 5.0 Mustang Tech 3
