Fox BMW Swaped 331 Stroker
RJ Brar
23
Hello Everyone im new to the stangnet family and i have a question about what cam to use for my application. I have a 95 bmw e36 with a 331 stroker in it, before i ask my questions i want to list all the parts i have used on it. i know someone these parts have no relations to my question but i just want t o put it out there what i used in case anyone is wondering.
Stock block Scat 1-94055BE Rotating assembly
Current CAM is Comp Cam xe282HR-12
Edelbrock 8840 Victor water pump
Edelbrock 7123 Performer RPM Intake manifold upper and lower
AFR 1422 185CC Heads 58CC Chambers
BBK Shorty headers
Comp Cam 19043-16 gold Rollers
75MM BBK Throttle Body (Whistles so bad)
32 IBS Injectors
MSD 8456 Distributor
Powering it all up is a microsquirt (Shout out @a91what for all the tuning he has done)
Taking the abuse is a t5 tranny
I have built this car for street fun and to be able to daily drive it but drifting it is my main goal. I live in Central California 209 near silicon valley. CHP and City cops are really serious around here with modded cars so i dont want to lose my car and get it towed. My Main Issue is that the cam i have in right now is not smooth at all basically shakes the whole car so what im looking for is a smooth idle cam that can still have my power. When i picked out this cam i wasn't thinking too much of it nor did i do my research on it all i seen was that it makes power so i just went with it. So please give me suggestions on which cam i can run that is smooth on the idle but i will still make good power up my setup. AND also if anyone can recommend any good throttle body that doesn't whistle my current BBK one is horrible, hows the SR performance ones from american muscle? I can post pictures if anyone is interested in seeing the setup. Thank you guys hopefully i made everything clear and didn't write too much thanks
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,134
6,032
204
31
Hillsborough county
+1 car pics...
FYI guys the cam does idle "smooth" now by most standards but has a serious chop to it. He only has 7-8 inhg vacuum at idle.
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,302
4,352
203
42
My car runs the same cam in a 331 turbo car. Only pulls 8-9in.hg at idle. At 1k its about 12in.hg. No vacuum leaks.
Vacuum is too low for my cobra booster to keep up. Needs a vacuum pump.
My advise would be an Ed Curtis FTI custom camshaft. He can grind one exactly the way you want for your set up. FlowTech Induction.
RangerJoe
I leave the horn on while driving
5 Year Member
Apr 26, 2010
2,666
1,232
174
Georgia
Custom always best. However, if that is out of the question, I ran and Anderson N41 for a while and really liked it. It will pull good to around 6000-6200, but the heads will definitely support more rpm. Not real up on the drift scene, but I assume sustained high rpms for long periods of time (more than 12 seconds). If so, the lower the rpms the better chance your stock block has of living.
Joe
RJ Brar
23
A custom ground cam would be the best way to go.
Accufab makes good quality throttle bodies.
Everyone on here loves car pics, post some up.
Thank you for the throttle body recomm. and i have discussed a custom cam with @a91what but as of right now im looking for something i can grab off the shelf.
RJ Brar
23
I didnt find any leaks on my either, Right now im looking to grab something off the shelf if anything pops up in your head? thank you
RJ Brar
23
Joe
i see the rmp range is from 2600-6200 from a quick search pretty much same as my current cam. Hows the tone on idle? Yes i want to keep it low dont want to mess up my block really soon.. Thank you
RJ Brar
23
Here's some pictures not full cleaned up yet. in the engine picture you can see im runing my exhaust from the front of the engine so i have the shortys running backwards and both connect into one.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,061
9,207
224
Massachusetts
N71 has a pretty aggressive chop to it. Hop on youtube and you can see a few vids with that camshaft
What are you looking for most? Tame idle? Unfortunately a lot of cams will have that tell-tale chop at idle. You might want to take a look at this cam
RJ Brar
23
Ok cool, does the limited wrap on that water pump pulley cause any cooling issues?
that was in the beginning i changed my setup now i mounted a ac compressor and it routs that way. i didnt have any issues running it that way but i wudnt recommend it, it wobbles like hell.
RJ Brar
23
Thank you for recommendation i will look into this.
HotFox
974
560
134
40
SE Michigan
That passenger side pipe feeding into the collector is less then ideal. You never want to feed a pipe like that at 90° on a natural aspirated engine. Turbo is alittle different beast where you can get away with less then ideal conditions as you are not relying on exhaust pulse waves to evacuate the cylinder.
Thread starter Similar threads Forum Replies Date
DarkoStoj 1968 Mustang Fastback Build Thread - GT350R Engine & BMW DCT Trans 1965 - 1973 Classic Mustangs -General/Talk- 10
C Ecoboost vs BMW 0-60 times???? 2015+ (S550) Mustang -General/Talk 0
F BMW for sale/trade Other Classifieds 0
F BMW 323i for Mustang Other Classifieds 0
A 1989 5.0 swap into a bmw M3 trying to hit a hp target Fox 5.0 Mustang Tech 18
RacEoHolic330 87-93 Bi-Xenon HID headlights. Custom e46 BMW projector retrofit. Interior Exterior Parts 1
MRaburn 2011 Ford Mustang GT vs 2011 BMW M3 Coupe StangNet Site News 0
MRaburn 2011 Ford Mustang GT vs 2011 BMW M3 Coupe 2010 - 2014 Specific Tech 21
B 5.0 V8 dropped into a BMW 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
BlackVert Twin turbo BMW 135 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
B FS:FT 2000 BMW 323ci Other Classifieds 1
SRT Handz Handz Detailed: 2001 BMW Z3 Roadster *Alpineweiss III* 1996 - 2004 SN95 Mustang -General/Talk- 13
0 the bmw m3 (fixed) 2005 - 2014 S-197 Mustang -General/Talk- 1
BlownStangGT Now you have to worry about bmw's??? 1996 - 2004 SN95 Mustang -General/Talk- 81
LordMustangGT My friends BMW Regional Forums and Event Information 7
sgw_88FoxGT BMW E30 M3 - 4 cylinders - 365 hp 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
RUNINAGT Deer -vs- BMW on the Autobahn, not for the weak!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
grey5.0beast BMW drift=Axle Pwnage 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
Aliate X This tops my BMW M6 kill.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
streethorse BMW's and brake dust........... 1996 - 2004 SN95 Mustang -General/Talk- 18
M 2001GT vs 2001 BMW M3 vert 1996 - 2004 SN95 Mustang -General/Talk- 18
grey5.0beast Clay barred the BMW 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Aliate X BMW M6 vs 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 48
0 Enjoying driving my AWD loaner BMW 330xi - impressions... 1996 - 2004 SN95 Mustang -General/Talk- 5
Pokageek ANOTHER FIRST TODAY!! The Home Owners Assoc claims my BMW is OFFENSIVE! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
BlueSaph95GT Playtime with a BMW 330xi 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
SRT Handz New BMW 335i Twin Turbo..... OMG!!! 1996 - 2004 SN95 Mustang -General/Talk- 25
J My unfortunate dealings with Tulley, BMW dealership in Nashua Regional Forums and Event Information 5
Vinyl66 I beat a BMW! Classic Mustang Specific Tech 14
Caldwell Is someone able to run a Carfax on a BMW for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
T BMW 540 clocked at 146mph on I-84 Regional Forums and Event Information 15
1994Vib.RedGT whats the general opinion on BMW M3's 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
chepsk8 Take a lap of the Nurburgring in a Le-Mans BMW! 1965 - 1973 Classic Mustangs -General/Talk- 3
Slow5.0 My BMW (winter ride) no longer stock 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
urban96 help i wrapped a sock around the camshaft in my BMW 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
C Poor BMW. 1996 - 2004 SN95 Mustang -General/Talk- 3
mustangphil Want to drive new 3 series BMW? At Qualcom this weekend. Regional Forums and Event Information 3
F Mustang makes top three list of most hated cars on BMW M3 forum... 2005 - 2014 S-197 Mustang -General/Talk- 127
hicalibrbulit BMW mechanic Regional Forums and Event Information 4
L RACED A 2004 BMW M3 SMG! 1994 - 1995 Specific Tech 6
F HUGE autox at the BMW plant in SC Regional Forums and Event Information 1
B OT: Replacing Glass (on an 87 BMW) 1965 - 1973 Classic Mustangs -General/Talk- 0
DFG 5OH BMW vs. Mustang GT 1994 - 1995 Specific Tech 21
chefster Shadowed a bmw 1994 - 1995 Specific Tech 4
Afastgts95 Finally beat the BMW M3 last night 1994 - 1995 Specific Tech 24
KingDiamond Encounter with a BMW... 1994 - 1995 Specific Tech 8
J whats it take to run with a BMW M3 SN95 4.6L Mustang Tech 15
D Cobra...BMW 1996 - 2004 SN95 Mustang -General/Talk- 32
D A BMW owner looking @ the 05's 2005 - 2014 S-197 Mustang -General/Talk- 13
J BMW side blinkers Mustang Sound & Shine All 3
