No, it's because you didn't specify things like whether or not you intend to run race or pump gas, and some people are missing the fact that you're running 10:1 compression. When you say "stock block," it doesn't really work that way. The block itself can take more boost than is feasible on pump gas as long as the power is kept in check, but boost is only a means to an end. The truth is that it lies completely in the tune, and the only sure-fire way to do this is to increase the boost incrementally and tuning as you go until you're not picking up power anymore. Then back it down a couple psi and a couple degrees ignition timing.
I think for what you're trying to do, I'd only run 6 or so until I dialed it in with a good tune. I think you'll have a hard time pushing 12 on pump without detonation or without lowering the timing so much that upping the boost is ineffective for producing more power.
