Borrowing Welds and slicks...will they fit the Saleen?
Mikie
the ahead of you horseman
Aug 2, 2000
517
Belmont NC
I am borrowing two 15x10 draglites with Hoosier slicks.
My question is, the backspacing on these wheels are 5.5"
Every search I have done tells me it needs to be 6.5"
Will these still fit or will I need a spacer or what?
Thanks for any help.
Mike
You're going to need studs, i don't know if you already know that.
Well if you have less of a backspace, the more the wheel and tire is going to stick out from the car.
For example I've seen a car with 15x8's with a 4.5" backspace and a 15x8 with a 5.5" backspace. The 5.5" backpace makes the wheel tucked in with the fender while the 4.5" backspace had a wider stance, sticking out from the car.
it is not an insurance thing.
without 3" studs you will only have 2-3 threads holding the wheel on
the weld rims have a thicker center section unlike your stock rims. this thicker center causes the wheel to be spaced farther out on the studs. thats why you dont run the welds on stock studs.
as far as i remeber, (been a while since i fitted my welds) I'm using the stock studs but the welds use real deep wheel nuts that got though the wheel to hold on to the thread of the stud way down.
like that, the shank goes though the hole in the wheel and holds on to the threads all the way down. A normal lug nut wont go though the wheel at all, it will just hold on to what threads protrude from the wheel...
i hope that makes sense.. its been a real long day.....
