i installed AFR 185 heads on the engine about 6 months ago. When i installed the heads i used an adjustable pushrod to check pushrod length to place the roller rockers in the right place on the valve. I got a pushrod that was .100 longer. i asked around and that seemed to be the going rate of what everyone was using. But i noticed that to get the right rocker placement and preload on the lifter, the jam nut for the rocker arms only screws on to the rocker stud about 4 to 5 turns. That seemed odd to me.
About two months later one of the exhaust jam nuts falls off at the race track. I install it back on and drive it home. I adjusted all the rockers again. well it lasted 4 months until last night when in the same night i broke 2 exhaust rocker studs off just under the jam nut. So now i know something is wrong!
Are my pushrods too long? Are the rocker studs are too short??? Why is it only the Exhaust studs breaking? Has anyone run into this problem?
I do spin this engine just over 6000RPM, and am now wondering if the studs are Flexing? Will I need a rocker arm stud girdle to help with flex?
Thanks
Dan
Thanks
Dan
