Fox Build Thread- Some Days I Should Of Let It Burn Down
Yes from my experience that mph is off by around 6-10mph. You should see 90 mph at a minimum(even with bad air). My 3 stock(ish) cars ran 92-95mph and with gears/tires-98-100mph. Even with higher temps/humidity something is amiss IMO. My 86 with just intake,exhaust,and stock 2.73 gears-Goodyear tires (before first rebuild) went 96mph(14.50's) and 2.xx 60 ft. You definitely need some better tires for the track and if you take .5seconds off that 60ft you'll see 1 second in et drop and pickup some mph.
Yeah I figured, the mph bothered me. Starting to think it has an explorer cam. Tomorrow I won't be able to run my drag radials ( Cheap Nittos 555R) due to them being an 1.5 hour away.
I'll play around with the timing and air pressure. Either way my 60ft is going to spin on the Toyos if they keep spraying the burn box. I'll try to roll out of the light at idle and see if that helps.
Reactions: 1 user
Well nothing to write home about from the track last night. I didn't get a single solid run in.
First run, no water sprayed on the pit. Yes I thinking this going to be a clean run. Burn out went well ( but my check engine light came on), line up against and another fox stocking. Lights trips. I tree him, shoot out to break the beams to start the time and bam engine died...... :loser:
2nd run it didn't die but clicked off 2nd and burn contest pedaled and third went fine then I guess I missed fourth??? Ah well :poo:.
Third run 2500 rpm launch and died sort of. Dumped the clutch and it cut off and the after about a second engine cut on and left.
:stig: :chin My thought currently was to kill it with :flame:but wife pointed out been there done that.....ouch:shutup:
Nonetheless the kids love the car at the track because they actually can walk and touch it and people think mad max theme on purpose.
Only thing I found out is there is more mph in the motor 91:rock:
I have been chasing a suspected vacuum leak, this was yesterday
I had a new set of plugs laying around
The yellow vacuum line is melted shut for EGR pressure regulator ( which I don't have) and all the other checked fine
I still have my doubts about this tube
So I bolted everything back up and still had the stumble that eventually loads up and backfires.
After checking the codes again same. So I had some 24s and a newish maf (calibrated for 24s) laying around. This was today
Reactions: 1 user
End result for now, I have to cut my air intake tube to make my CAI work.
The car ran a lot better, however while checking the codes during running. I must of missed it before but I have code 41.
Which some say is the ground on the back of the engine. Sure enough it was broken.
Does this have to go to the engine or can it go to the firewall?
Reactions: 1 user
Great thread. Reminds me of 15 years ago when I put the 82 together from a $50 body with a salvage title and a $450 255 2v Capri donor car.
Appreciate it, it will probably never be a show car but it's fun for what it is. I need to spray it one color and strip/paint the engine bay.
So while trying to resolve my codes I have. My ignition switch is flaking out and figured I should replace it before it left me stranded
View: https://youtu.be/-ayc6-IDH6U
Also I tried to resolve the charcoal canister codes by running the vacuum lines to it with the solenoid and ran into a few issues.
One my charcoal canister is the four cylinder one
So question would be do I just run the canister with fuel tank vent line in series with the solenoid and then to caniste while capping the intake?
Moving on when I installed the 24lb injectors I ran into some issues due to the mass air is calibrated to fenderwell. However, LMRs CAI was a litte tight and well I mended it sort of,
Took the car out and it runs great .....still have codes tho
Looks almost on point IMO
Reactions: 1 user
@jrichker are the O2 supposed to be 3 pin or 4 on a 93
Use 3 pin O2 sensors for the V8 engines.
The 4 pin O2 sensors are for the 4 cylinder engines
If there are o2 sensor problems you can have a 44/94 code.
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 11-Jan-2015 to add check for fuel pressure out of range
Code 41 is the passenger side sensor, as viewed from the driver's seat.
Code 91 is the driver side sensor, as viewed from the driver's seat.
Code 172 is the passenger side sensor as viewed from the driver's seat.
Code 176 is the driver side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (L\RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Check the fuel pressure – the fuel pressure is 37-41 PSI with the vacuum disconnected and the engine idling. Fuel pressure out of range can cause the 41 & 91 codes together. It will not cause a single code, only both codes together.
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Check for a clogged air crossover tube, where one or both sides of the tube clog with carbon. A missing crossover tube can set codes 44/94.
Revised 21 Sep 2012 to correct the description of the process that sets the code and include Thermactor Air System diagram.
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them.
Code 44 RH side air not functioning.
Code 94 LH side air not functioning.
The TAD solenoid/TAD diverter valve directs smog pump output to either the crossover tube attached to the cylinder heads or to the catalytic converters.
The O2 sensors are placed before the catalytic converters, so they do not see the extra O2 when the smog pump's output is directed to the converters or the input just before the converter.
The 44/94 code uses the O2 sensors to detect a shift in the O2 level in the exhaust. The smog pump provides extra air to the exhaust which raises the O2 level in the exhaust when the smog pump output is directed through the crossover tube.
When there is an absence of increase in the O2 levels when the TAD solenoid/TAD diverter valve directs air through the crossover tube, it detects the lower O2 level and sets the code.
Failure mode is usually due to a clogged air crossover tube, where one or both sides of the tube clog with carbon. The air crossover tube mounts on the back of the cylinder heads and supplies air to each of the Thermactor air passages cast into the cylinder heads. When the heads do not get the proper air delivery, they set codes 44 & 94, depending on which passage is clogged. It is possible to get both 44 & 94, which would suggest that the air pump or control valves are not working correctly, or the crossover tube is full of carbon or missing.
Testing the system:
Note that the engine must be running to do the tests unless stated otherwise. For safety’s sake, do test preparation like loosening clamps, disconnecting hoses and connecting things to a vacuum source with the engine off.
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The following computer tests are done with the engine not running.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Turning the ignition to Run with the computer jumpered to self-test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
The following computer tests are done with the engine running.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation with the engine running. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Typical resistance of the solenoid valves is in the range of 20-70 Ohms.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about themCodes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Check for a clogged air crossover tube, where one or both sides of the tube clog with carbon. A missing crossover tube can set codes 44/94.
Testing the system:
Reactions: 1 user
I figured it was time to replace the old coil and well, no difference. Car actually recently has been running if that intermittent miss again. Idles fine, start to drive and it starts to break up and back fires. WTH :scratch: :bang::dammit:
Same codes as before, it didn't start running bad again until I changed out the correct O2 sensors.
Also no cats which means I should be good on 44/94
What plug is this?
Little more today, the ignition switch didn't fix the random click then crank. So a bought a new solenoid.
I need to clean up the rats nest with a fuse block.
Some help for the starter solenoid wiring is here...
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
There is a whole No Crank checklist, tag or PM if you would like it added to your post
Reactions: 1 user
Awesome I was looking for that. I hooked everything up right.....the second time:nono:. The starter would stay on. I had to find the schematic for the solenoid I used the poles were switched from the OEM position:eek:. Flipped them voila
Spot the difference
I had a sneaking suspicion that the dizzy may be the source whether it was the Pip or TFi due to it being intermittent while driving.
Well notta, actually drove the same. I did find out my Tps was out of range when I had the DMM out today.
So my codes have remained the same and it's for the emission equipment I do not have.
I'm going to start tracing the harness
BTW @jrichker way back when; my blue fuse link burnt up. I found a matching gauge wire with an inline fuse. Well just checked the fuse and it's a 20 amp, which is too much correct ?
So my question is there someone who sells a replacement fuse link?
And/or just change the fuse to something lower.
Update
Car runs and drives great.
To Do list:
Steering needs to be adjusted
An my electric fan keeps burning up relays
Look into Strange struts with UPR coil overs.
Just collecting parts and debating on painting the car. Tho I kind of want to find a clean 5.0 roller like this:
But the guy cut up a perfectly good low mileage Reef Blue coupe and wants too much.
Anyways my car keeps finding nails
Primarily due to where I live
But least it drives yay
Reactions: 1 users
