P ponyride94 New Member Aug 19, 2009 2 0 0 vineland new jersey Aug 19, 2009 #1 Aug 19, 2009 #1 could I install camber bolts on my 94 mustang to get proper camber? I have a 2.5 neg. camber on the right front wheel.
Chythar Recently finished repairing my rear Dirt-Old 20+Year Member Aug 26, 2004 2,370 145 113 Foothill Ranch, CA Aug 19, 2009 #2 Aug 19, 2009 #2 Sure, I've done that on my Mustang. The camber bolt goes in the top shock hole, they give you enough adjustment to get the wheel straight.
GTA_V6_Mustang Active Member Nov 29, 2004 1,326 3 39 Miami, FL Aug 19, 2009 #3 Aug 19, 2009 #3 Chythar said: Sure, I've done that on my Mustang. The camber bolt goes in the top shock hole, they give you enough adjustment to get the wheel straight. Click to expand... +2 i did the same thing on mine worked just fine.
P ponyride94 New Member Aug 19, 2009 2 0 0 vineland new jersey Aug 21, 2009 #4 Aug 21, 2009 #4 I intstalled it yesterday, But I noticed that the camber went off again, maybe I didn't tighten the lower bolt enough?
Chythar Recently finished repairing my rear Dirt-Old 20+Year Member Aug 26, 2004 2,370 145 113 Foothill Ranch, CA Aug 21, 2009 #5 Aug 21, 2009 #5 Both bolts need to be torqued down to spec. The new camber bolt should have the same torque as the original bolt - isn't it 110 ft/lb? Or is if 130? I don't remember offhand.
YEAHLOH95 Founding Member Nov 19, 2001 1,249 3 39 EVERETT,PA Aug 21, 2009 #6 Aug 21, 2009 #6 you probably didnt get it tight enough, can you mark it around the strut to see if its moving?
