J Juanio361 New Member Jun 11, 2016 6 0 1 Jun 21, 2016 #1 Jun 21, 2016 #1 Any one used camber bolts on there mustangs before? I have 98 GT. Are they any good?
J jeno_labanca Member Oct 10, 2014 109 6 18 Jun 21, 2016 #2 Jun 21, 2016 #2 Well what are your intensions with the car Sent from my LG-H811 using Tapatalk
J Juanio361 New Member Jun 11, 2016 6 0 1 Jun 21, 2016 #3 Jun 21, 2016 #3 jeno_labanca said: Well what are your intensions with the car Sent from my LG-H811 using Tapatalk Click to expand... Fix the camber issue with the car. It seems it has lowering springs and its visible it has negative camber.
J jeno_labanca Member Oct 10, 2014 109 6 18 Jun 22, 2016 #4 Jun 22, 2016 #4 I would just do caster camber plates but camber bolts work if you not doing aggressive cornering and such can cause them to break Sent from my LG-H811 using Tapatalk
J Juanio361 New Member Jun 11, 2016 6 0 1 Jun 23, 2016 #5 Jun 23, 2016 #5 jeno_labanca said: I would just do caster camber plates but camber bolts work if you not doing aggressive cornering and such can cause them to break Sent from my LG-H811 using Tapatalk Click to expand... I've seen the camber/caster plates. I like em but I'm on a tight budget. Hence the camber bolts. I don't do no aggeressive cornering. Maybe a fish tail every now and then.
J jeno_labanca Member Oct 10, 2014 109 6 18 Jun 23, 2016 #6 Jun 23, 2016 #6 Well then go for it Sent from my LG-H811 using Tapatalk
