Camshaft advice for 351w
Nov 20, 2018
QLD » Sunshine Coast » Maleny
Hey guys im getting sick of tapping from my non adjustable rockers and have decided to go all out. Im looking at a cam called lunati voodoo https://www.summitracing.com/int/parts/lun-10350703k. Im also getting these adjustable rockers https://outlawspeed.com.au/shop/ytst2004. The cam comes with everything except pushrods. Are these products all i need to upgrade my cam? Will the springs and rockers withstand each other? Im open to any and all options in regards to what i should do here but im really keen to try and do the job myself. Also is it cheaper to just buy new heads with adjustable rockers?
  • Sponsors(?)
rbohm
SN Certified Technician
Apr 12, 2002
6,669
540
204
61
tucson,az
depending on what you want from this engine, the cam might be a bit too big, but acceptable. the rpm range is 1800-6200 rpm which makes for a good street/strip cam where you are going to spend a few weekends per season at the strip. so be aware of the slightly soggy off idle response from this engine if you use this cam, unless you are building a stroker motor.
as for the rocker arms, yellow terra has a good reputation and should do you quite well. that said there are sets out there that are just as good or, better imo, that are also less expensive;
https://www.summitracing.com/parts/cca-1631-8/overview/make/ford
https://www.summitracing.com/parts/cca-17043-16/overview/make/ford
https://www.summitracing.com/parts/sum-g6996/overview/make/ford
https://www.summitracing.com/parts/cca-1831-8/overview/make/ford
https://www.summitracing.com/parts/lun-15385-16/overview/make/ford
any of these sets are about half the cost of the yellow terra rockers, including the lunati voodoo rocker arms.
rbohm
Apr 12, 2002
6,669
540
204
61
tucson,az
installing the rockers on stock heads and studs is simple, you just bolt them on. i would however recommend highly that you invest in screw in studs with that cam. the stock press in studs have a tendency to pull out with heavier springs.
as for valve to piston clearance, you might be ok, but it is always best to check the v/p clearance to avoid any issues.
Nov 20, 2018
Alright cool. With all the machine work costs added its starting to lean economically towards after market heads do you think? If this is the direction best suited could you please help me with what are the better heads i should be getting. This car will not be raced. I just want a lumpier sounding cam for the street
rbohm
Apr 12, 2002
6,669
540
204
61
tucson,az
Thread starter Similar threads Forum Replies Date
loganburks88 302 Street/strip Camshaft Advice 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 33
David'SN95 Camshaft advice for my rebuild 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
W First Motor Build Need Advice 2015+ (S550) Mustang -General/Talk 1
J Engine Need Help With Valve Train Fox 5.0 Mustang Tech 3
Chewievettte Need Camshaft Advice 2.3L (N/A & Turbo) Tech 3
M Need camshaft advice please Fox 5.0 Mustang Tech 8
E Need some camshaft advice please Fox 5.0 Mustang Tech 5
B 2011 V6 - Startup Tick Noise - Camshaft Caps Question - TSB 12-1-17 2010 - 2014 Specific Tech 2
A WTB/Trade Crane 444225 Camshaft Engine and Power Adder 0
S Camshaft recommendations 2005 - 2014 S-197 Mustang -General/Talk- 3
S Camshafts for sale 2005 - 2014 S-197 Mustang -General/Talk- 2
PakstinN cam swap w/ 11r 190 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
kiddiccarus 1995 vs 2002 camshaft synchronizer (Need Help) SN95 V6 Mustang Tech 14
5 Crankshaft or camshaft position sensor? Car stalls. 1994 - 1995 Specific Tech 5
M Fox Camshafts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Foxbody1988 Engine Camshaft questions and supercharger Fox 5.0 Mustang Tech 0
9 How do i re-sync the Camshaft position Sensor SN95 V6 Mustang Tech 2
9 1995 3.8 v6 Camshaft Lift { Answer Inside} SN95 V6 Mustang Tech 0
O Camshaft help 1996 - 2004 SN95 Mustang -General/Talk- 1
E Engine Stock camshaft specs 5.0 Fox 5.0 Mustang Tech 3
mattbaker302 camshaft upgrade 1965 - 1973 Classic Mustangs -General/Talk- 13
Mustang5L5 SOLD Trick Flow Stage 1 camshaft Engine and Power Adder 0
D Camshaft Synchronizer SN95 V6 Mustang Tech 4
S 1990-Camshaft alignment 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Ultra90GT Engine 1990 Opinions on camshaft Fox 5.0 Mustang Tech 4
K Fox 1989-looking for the best camshaft 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
T Camshaft Options 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
K Squeaking/rubbing sound from camshaft. Need help 1996 - 2004 SN95 Mustang -General/Talk- 0
0 Screeching noise 1996 - 2004 SN95 Mustang -General/Talk- 1
Ian Ranchero Experience with summit cams and lifters? 1965 - 1973 Classic Mustangs -General/Talk- 0
K Engine 1987 spun Camshaft Bearing? Used a borescope through distributor. Fox 5.0 Mustang Tech 5
E Can someone tell me what camshafts are this? 2005 - 2014 S-197 Mustang -General/Talk- 1
MoDriver SOLD 1985-1988 Ford Thunderbird 2.3L Turbo SOHC 8V Camshaft (Should work in many 2.3L Mustangs) Engine and Power Adder 7
Q 2008 Mustang GT DTC P0345 P0349 2005 - 2014 S-197 Mustang -General/Talk- 4
H Cams and heads 1994 - 1995 Specific Tech 1
E Camshaft engraving 2005 - 2014 S-197 Mustang -General/Talk- 2
S A survivor from the days of Modded Mustangs forums. Need feedback on Camshafts 1996 - 2004 SN95 Mustang -General/Talk- 1
Cam Coppola Comp Cams XE 270HR camshaft 1994 - 1995 Specific Tech 0
GetOuttaDodge Anyone In Eastern Nc Who Can Help? The Welcome Wagon 4
E 99 3.8 Camshaft SN95 V6 Mustang Tech 1
J Bad Camshaft Position Sensor 2 2010 - 2014 Specific Tech 1
PakstinN Buying An Ed Curtis Cam 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
PakstinN Bent 302 Cam?? Fox 5.0 Mustang Tech 2
F Camshaft Id Fox 5.0 Mustang Tech 0
J Expired Ford V8 Cam Tool Kit For Sale - $150 Other Classifieds 0
S 393w Camshaft & Opinions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
A5literMan Afm Camshafts On Sale. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R 95 Cobra Camshaft 1994 - 1995 Specific Tech 4
E Is Cam Degreeing Necessary 2005 - 2009 Specific Tech 3
E Is Cam Degreeing Necessary 2005 - 2009 Specific Tech 0
