Can I use Cobra 93 ECM on my 1990 Mustang?
Sep 11, 2006
66
93 stock MAF. I have my injectors replaced with 24# (ford racing) and TB is 70 MM. Cobra intake, GT-40 X heads, B cam.
Do I need to replace the harness as well ? or it should work fine?
I run through many troubles since I had these mods.. I installed PRO-M MAF calibrated for my mods, after few months, I added TwEECer tune , but nothing seems to work togather.. the car is always locking the power it should give and it hesitates alot when you accelerate !
Any ideas on this swap with 93 stock parts?
Mustang5L5
Car used in adult film "Highway Gangbang-InDaButt"
SN Certified Technician
Feb 18, 2001
28,198
5,317
224
Massachusetts
You need a 1993 cobra MAF to use that EEC, in addition to 24# injectors you already have
Sep 11, 2006
66
Ok , so that's the cobra 93 stock MAF , right?
Do I need to change the main harness ?? or 90's harness will just work fine?
Mustang5L5
Feb 18, 2001
28,198
5,317
224
Massachusetts
Yes, stock 70mm MAF from a 1993 Cobra
Mustang5L5
Feb 18, 2001
28,198
5,317
224
Massachusetts
The plug is the same. The wiring, ultimately, is the same.
All you need to do is plug in the EEC, the MAF, and use 24#ers and good to go
