I posted earlier, but hit a dead end. In my earlier post I had a major misfiring problem. So I checked the engine codes and came up with 22, 35, 51, 53, and 54. Which are all problems with the tps, egr, map, and act, evr sensors. So Jrichker sugessted i check the sig return line on all of these sensors with the battery ground. All checked out with resistance above 1 ohm. So I checked resistance to the 10 pin connector and to the ecu on the sig rtn line, all checked out fine. I then cracked open the computer to see if pin 46 was broken inside the case (it wasn't). Then checked the two ground pins to the battery to see if they had connection, which also checked out fine.
While I was messing around with this i also checked the fuel pressure, which was 40 psi at idle, with a 5 to 10 lb drop when it was revved to about 2500 rpm (don't know if this is normal) I checked the vaccuum at idle which was useless since the idle was nonexistant to begin with. But when i held the throttle at 2000 rpm the gauge held a steady 15 inches which ruled out valve train problems. And I checked the timing which was set at about 12 deg.
So I went back to the sig rtn line problem and made a jumper wire from the rtn line on the 10 pin harness to the battery, then ran the car for several miles, at part and full throttle. I then dumped the codes and came up with 22, 67, 29, and 34. The car seemed to run better but the idle still sucked. So I cleared the memory, took the jumper wire off, and test drove it again to see if I would get the same result i had to begin with, sure enough the same original codes popped up, so the jumper wire did clear up some of the problem. I cannot figure out if i should be looking at one sensor for the idle problem or if the computer needs to be replaced, wiring harness etc. etc.
While by now i'm getting pretty damn familiar with the wiring on this car I still cannot figure out what the main problem is. The car is a 1989 5.0 with a holley systemax intake, mass air, and a b303 cam. Which i find odd because a mass air vehicle shouldn't pull a 22 MAP error or a 29 VSS error.
Any help would be greatly apreciated.
