Car Has Low Rpm At Highway Speeds
apothicca
56
so I have seen a lot of threads about cars with low RPMs not accelerating and it is usually the Catalytic converter from what I have seen.
But my car gets to 55mph fine, but after that the rpms go back down to what it has during idle, around 700-1000.
If I floor it, it takes a second or too, and then it suddenly lurches forward. What is going on here? Any ideas? Thanks
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,838
505
194
Houston Texas
I give up. What Model year Mustang are we dealing with?
Do you think that maybe the DTC codes have something to do with the lack of performance?
IMO the DTC code that should be attacked first is the P0340. Anytime the PCM calls out a "circuit malfunction" think there's something so wrong with the circuit that the PCM is unable to perform trouble shooting. One of the first things to look for is a wiring harness fault.
But.....it happens that sometimes a bad alternator diode can "cause" a false bad cam sensor signal. For this reason I always suggest starting every trouble shooting session with a review of the battery and charging system.
>>>From Ford manual
P0340 - Camshaft Position (CMP) Sensor Circuit Malfunction
The test fails when the PCM can no longer detect the signal from the CMP sensor.
  • CMP circuit open
  • CMP circuit short to GND
  • CMP circuit short to PWR
  • SIG RTN open (VR sensor)
  • CMP GND open (Hall effect sensor)
  • CMP misinstalled (Hall effect sensor)
  • Damaged CMP sensor shielding
  • Damaged PCM
Harness routing, harness alterations, improper shielding, or electrical interference from other improperly functioning systems may have intermittent impact on the CMP signal
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
apothicca
56
it's a 1995 v6, I tried the test and never got a negative reading, it was also 14.5-6 volts no matter if the lights and fan were on, or the radio. Revving it also made no difference.
I don't know if they do since I think it had these codes for awhile, but it really only started to get driven a week ago. And then lack of performance was only really noticeable yesterday.
wmburns
Aug 14, 2009
5,838
505
194
Houston Texas
soooooooo. What have you done to rule out a wiring fault to the cam sensor? If no wiring fault found then likely it's time to consider a cam sensor and shaft replacement.
apothicca
56
Is the wiring thing the alternator check? I haven't looked at it other than that I've been busy with school and work.
I figured out it's the transmission, if I turn off overdrive it works fine. So I checked the fluid and it was a little low, added fluid and now it is running fine. I will have to save up some money since I think the transmission might be on its way out. I'd rather fix this car then get another one that has an unknown history.
I'm debating on doing a fluid change or leaving it as is since I've heard it is bad to do it on transmissions with a lot of miles.
wmburns
Aug 14, 2009
5,838
505
194
Houston Texas
If your transmission level is soooooo low that it's slipping because of low level than continued operation will only harm the transmission. Short sighted not to address (IMO).
Likely you have more than one problem. The cam related DTC isn't being caused by the low transmission fluid level.
The other DTC codes are usually related to a vacuum leak.
apothicca
56
Well, it wasn't that low, but barely any was on the stick. I imagine the transmission being on it's way out now after 20 some years is not uncommon, so I am saving up to have it serviced (rebuilt or replaced, probably rebuilt cause $$$)
Thread starter Similar threads Forum Replies Date
9 Car has no low end torque after PI swap SN95 4.6L Mustang Tech 20
newstangman My Town Car has more low end torque SN95 4.6L Mustang Tech 8
R Engine Car has no power under acceleration, but has no codes 1994 - 1995 Specific Tech 3
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
J 04 GT New intake manifold and car now has a rough idle 1996 - 2004 SN95 Mustang -General/Talk- 5
R My car has trouble starting 1996 - 2004 SN95 Mustang -General/Talk- 14
S 93 5.0 5speed car starts runs strong turn it off and it acts like it has a dead batt The Welcome Wagon 0
8 Engine need help car has a hiccup Fox 5.0 Mustang Tech 7
BlakeusMaximus My Son Has A Nicer Car Then Me! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 67
M Car Has Been Sitting 3 Years SVT Tech Forum 1
O Car Has Reverse, But Problems With Forward Overnight? 1965 - 1973 Classic Mustangs -General/Talk- 2
TwinturboHoward Help Needed Diagnosing Why My Car Has A Bad Stumble Miss At Wot Only Fox 5.0 Mustang Tech 15
T 93 Cobra Fuel Issues-loading Up After Car Has Been Off The Welcome Wagon 0
02 281 GT SN95 The Noise My Car Has Been Making... (video) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
KyleEBK Car Has No Battery In Front.i Want To Get 1 In There. Help Fox 5.0 Mustang Tech 7
11sec. Engine Car Has Been Cutting Out?? SN95 4.6L Mustang Tech 4
Ant85 Has Anyone Seen This Car Before? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Moodswing5.0 Engine Car Sat For A Week, Now Has A Loud Tick Fox 5.0 Mustang Tech 5
betke76 Has Anyone Used Lost-car-registry? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
from6to8 Car Has Been Hard To Start Lately 1994 - 1995 Specific Tech 5
T Has Anyone Changed The Oil Pan Gasket With Motor Still In The Car? 1994 - 1995 Specific Tech 13
iBlackburn Has Anyone Every Put Auto Tape On Their Car? 2010 - 2014 Specific Tech 5
S Car Wont Start, Has Spark And Fuel 1994 - 1995 Specific Tech 4
pissedoff92 Car Breaks Up And Has No Power Over 2k Rpm Fox 5.0 Mustang Tech 18
srtthis Race Car Now Has Flame Throwers... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 31
G car has been sitting for 6 months.... SN95 4.6L Mustang Tech 4
fivespeedsteed Has anyone out there fixed their quarter window moulding while its on the car? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Three50won Curious, has your car ever done something... 1996 - 2004 SN95 Mustang -General/Talk- 8
blackened88lx Car has been sitting, runs funny now. video 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 53
enferno strange c4 leak when car has been sitting Classic Mustang Specific Tech 4
M Car Shuts off and has an erratic idle Fox 5.0 Mustang Tech 5
68dustin borgenson steering conversion? who has drove a car with the install? Classic Mustang Specific Tech 3
C Car has sat for awhile SN95 V6 Mustang Tech 1
281pony Totally baffled. Car has a miss/dies when going in reverse. Fox 5.0 Mustang Tech 14
Night Shifter my car has teh attitude problem too now... 1996 - 2004 SN95 Mustang -General/Talk- 43
L My car has problems Fox 5.0 Mustang Tech 4
Riceslayer302.0 has anyone here swapped a 4 eye nose on an aero car? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
1 I need to pass emissions (car has x pipe) SN95 4.6L Mustang Tech 12
D Has anyone bought from wUnder car parts 1996 - 2004 SN95 Mustang -General/Talk- 0
H Need Help...Car has started shaking and exhaust tone is different Fox 5.0 Mustang Tech 12
R Ever wonder if your car has bad juju? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
T help car has no power 2.3L (N/A & Turbo) Tech 12
7upstang91 My Car has a Mind of It's OWN! Fox 5.0 Mustang Tech 14
V Car has not power after battery?? 2.3L (N/A & Turbo) Tech 11
R Anyone Know what cams and heads this car has? SN95 4.6L Mustang Tech 4
S Car has a miss SN95 4.6L Mustang Tech 1
99FiveOh Has the economy affected spending on your car? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
M Car has no throttle, need help SN95 4.6L Mustang Tech 12
Yellow302 Car has no power, doesn't rev well and jumpy. Spark issue? 1994 - 1995 Specific Tech 24
juiced_94gt Car wont charge, New alt. and has power going to it!!! 1994 - 1995 Specific Tech 8
