1988 5.0/AOD/4.10
MAF system
About 2 weeks ago the car started running sub-par.
It started out barely noticable, but has gotten progressively worse.
It has been several months since it had basic tuning done, so we:
Changed plugs, wires, cap, and rotor.
Cleaned the K&N and MAF.
No CEL
Car had new o2 sensors less than a year ago, and they look great.
MAF is only a few months old, and looks great, but we did shoot it with cleaner.
Injectors are less than a year old.
The car runs smoothly at times, right when it is first started, and after it is warmed up.
However, shortly after start up until hot it runs roughest.
When driving, it runs smoothly if your foot is steady on the pedal.
If you accelerate, it surges and seems to have a light intermittent miss.
If you decellerate, it runs roughly for a time until it you steady the pedal again.
None of the tune up stuff worked, and it continued to decline.
The fact that it runs worse when moving the pedal, we checked the TPS.
It was .7v closed and 3.4v WOT.
The steady wire was 4.6v.
I thought the numbers were wrong, so we replaced the TPS with new.
No change.
All grounds have been checked.
When it is missing at idle, pulling plug wires or injector wires doesn't seem to find anything. There is no one cylinder that seems to be a culprit.
Anyway, the engine has lost a great deal of power under load.
Surging acceleration.
It runs fine at high rpm, so long as you have a steady throttle, so we have shied away from the one last 'tune up' item we haven't done, which is fuel filter. It doesn't act like it is running out of fuel.
We checked for vac leaks, none are apparent.... I know they can be tricky though, and even the brake booster could leak, but we have no reason to believe this yet.
Ideas?
Oh, module and coil are only a few months old, and the fact that it runs better warm are contraindications for failure of these items. We do have known good spares though.
MAF system
No CEL
No change.
Ideas?
