2003 Mach 1, 128,000 miles, ccrm replaced 4/2015 (A/C blowing hot, fan not working), then worked good. Shortly after, began to overheat & A/C blowing hot. Person that put in CCRM April 2015 no longer there. Took car to another repair shop, was told I need new fan, it's overheating, once overheating is fixed they'll look at A/C. Wasn't comfortable with that & took it elsewhere. This time I told mechanic to check ccrm, left car. Came back, & YES, it was ccrm & was replaced. Figured the one just installed was faulty. This was on 8/2015. Shortly after, started having overheat problems & drove very little, took back roads to keep from sitting at traffic lights. Didn't turn on A/C. Had to replace other items: clutch, brakes, tires, broke radiator hose, & couldn't have overheat issue looked at yet. FINALLY took car in for overheat problem 2 days ago. Needed flush & thermostat checked.Thermostat sticking & was replaced. Drove home, then decided to go somewhere...FINALLY with A/C, being 3rd summer in Florida without A/C. I was reluctant, car was running OK, & after having SO many problems with overheating & A/C, but, it's HOT & need A/C. Turned it on, worked great, really cold air, for 5 minutes, then hot air. I continued to where i was going, about 5 miles.When I pulled in, car dies. Try to start it, had a hard time starting, then started up...so something is definitely wrong, it's always started right up. Left to go back to repair shop & upon acceleration, there's a noise, I kept going slowly. Stalls at 1st 2 lights, hard start, & still acceleration noise. 3rd light, stalls, won't start. Stuck, call for tow truck. Still sitting in road after 20 minutes, I try to start it to just get OFF road. Starts right up & as I gas it to get over to a lane, it's not going, like not getting gas. Then it kicked in & drove good long enough to get off road then died again. Looked under hood & saw a little water had come out of radiator, so overheating a little? Is fan not running, it was OK earlier that day. Then towed to repair shop. Sounds like fuel pump? Maybe. No A/C, potentially fuel pump problem (didn't have before 1st 2 ccrm replacements), & overheating a little due to fan maybe not coming on?, so ccrm again? It never needed a fan, it was the ccrm. If it is that, this will be the 4th one to replace in less than 1-1/2 years (including the original), & would have been even a lot shorter time if I didn't get sidetracked with other repairs. 1st one replaced 4/2015, replaced again 8/2015, figured the ccrm was just a bad part. But now, another one. What could be happening, what can be fouling out the ccrm?
