"CHECK OIL" LIGHT
svtboy91
i have a 89 gt hatchback, like every 3 weeks the check oil comes up, and i check the dipstick and i gota add some oil to the engine. my driveway is perfectly clean, so its not leaking to the ground. is there a leak u may know that is common with this stangs? please help me
P.S. my engine is stock
3 major leak spots.
Rear Main Seal
Oil pan gaskets
Oil sensor gaskets.
If those are dry, you are prob buring oil then...either rings, or valve seals
X2 - Also probably burning oil. If it is, you might want to consider using a thicker oil ? It wont "stop" the consumption, but might slow it down?
