Checking fuel pressure
2003 4.6 I do have the shrader valve on the fuel rail however I need the adapter to fit the valve, purchased a fuel pump test kit and it seems to be lacking a connector to go from my gauge to the schrader valve, the end of my gauge is a 1/4 inch fitting so I need an adapter to go from 1/4 inch to the shrader valve. Do you know what adapter I would need? I can find some but they don't have the part that would open the core in the valve?
Thanks
There is a fuel pump switch, sometimes called an inertia switch located at the back of the trunk on the drivers side.
You might push the reset button in case it inadvertently got activated. This is a pic of where mine is, 02 GT.
