Cleaning Underside Of Engine Bay.
billison
I like tinted tail
2,578
1,084
184
stl
Ok, looking to clean the years old oil and what not off the bottom of the engine Bay Area. Mainly the oil pan area and steering rack.
I'm reading of using Brake clean but I don't wanna start melting gaskets or boots.
  • Sponsors(?)
Boosted92LX
SN Certified Technician
Dec 19, 2010
6,085
4,528
214
Purple power or super clean. Don't get it your eyes, it has a mild caustic in it. Soak, scrub, rinse.
Reactions: Davedacarpainter
Davedacarpainter
I think I've messed my pants
Nov 28, 2015
11,884
11,327
193
57
Discordia
I know that I used some gunk heavy duty degreaser, it worked really well.
I went to a car wash, popped the hood and hosed it all down below and above.
I forgot how long I let it soak, I used whatever time the directions said. Then power washed it off.
Everything looked nice and clean. Made changing out an oil pump, rear main seal and timing cover gasket a lot less of a dirty fix.
Onefine88
Previously 89SSC18
1,421
782
154
You'd be amazed at how good Purple Power and a pressure washer works on a nasty, greasy engine and bay.
Soak, blast and repeat!
Reactions: Boosted92LX
Boosted92LX
Dec 19, 2010
6,085
4,528
214
This. I've used Gunk. Purple power beats the chit out of it. NOTHING I've ever seen, including acetone works as well.
Boosted92LX
Dec 19, 2010
6,085
4,528
214
Where can I pick purple power up locally?
Oreilly or Autozone. Don't remember which. They both sell a version. Castrol super clean or purple power. Same product.
billison
I like tinted tail
2,578
1,084
184
stl
This was much easier than expected. Spayed with mean green, waited, sprayed again, waited, then pressured washed and watch the grease just come off. I'm constantly amazed how clean this car is under the dirt and grime.
74stang2togo
Oooh! CT!!!
Mod Dude
Mar 7, 2002
7,295
3,214
224
Purple Power has got to be the best degreaser out there. I do my driveway with it every 2-3 months. Turns the spot where my Mustang leaks a little oil and power steering fluid back into like-new concrete, and gets rid of any little "oops" moments that oil changes and maintenance have left behind. I've used it to de-grease many an engine bay, and to pre-treat laundry and clean greasy sinks and bathtubs as well. (Happens when you turn wrenches for a living).
Onefine88
Previously 89SSC18
1,421
782
154
I keep Purple in stock here at the house. I have a large Rubbermaid tote out in my barn full of water and Purple Power. I keep the lid on it so whenever I need to clean up something car related, I drop it in. Let it soak for awhile, scrub if needed and rinse it.
You guys should try that on an old used intake. comes out clean inside and out.
Thread starter Similar threads Forum Replies Date
James V Fox How to clean underside of lower intake? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
N Best way to clean and strip underside? Classic Mustang Specific Tech 38
Driver460sz Engine Ran fine, cleaned throttle body, blows sweet white smoke now. Fox 5.0 Mustang Tech 8
0 For Sale 2008 Shelby gt500 clean title..please read entire post S197 Mustangs For Sale (2005-14) 0
Spikely15 Progress Thread Clean slate! 1965 - 1973 Classic Mustangs -General/Talk- 10
J Water sloshing behind/inside dashboard - Carpets wet - Cowl drains are clean 2010 - 2014 Specific Tech 1
N For Sale 1993 LX Hatchback Fox Body Mustangs For Sale (1979-93) 4
M Engine Exhaust port cleaning Fox 5.0 Mustang Tech 1
gearhead77 General clean-up 89 GT 'Vert questions. Mustang Sound & Shine All 0
Real time recon The best cleaning/waxing stuff on the planet 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
C 89 GT Vert - Finally cleaned it up and took pics 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
J For Sale 1994 Mustang GT Autocross/HPDE setup, very clean, California. SN95 Mustangs For Sale (1994-04) 1
T Cleaning 1965 white interior Mustang Sound & Shine All 0
White Wolf Cleaning 02 Sensors 2005 - 2014 Specific V6 Tech 0
hoopty5.0 Progress Thread Hoopty5.0's non-hoopty-clean-up-project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 618
E water spots and possible scratches on headlights, any recommendations on cleaning headlights? 2015+ (S550) Mustang -General/Talk 0
billison Clean battery install... need ideas. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 80
B Drivetrain Speedometer Shop used grease, need to clean cable? Fox 5.0 Mustang Tech 5
K fuel injector service/cleaning 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S Cleaned engine block with scotch bright 4.6 2V SN95 4.6L Mustang Tech 6
markinms Engine Best way to clean a GT40 Intake (very greasy/dirty)? Fox 5.0 Mustang Tech 6
jedi_jackson Gauge Cluster Cleaning 1996 - 2004 SN95 Mustang -General/Talk- 0
D Cleaning up engine while its out 1996 - 2004 SN95 Mustang -General/Talk- 3
95BlueStallion Clean local 4 eye for sale 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
A What to clean Build Up under the spoiler? 1996 - 2004 SN95 Mustang -General/Talk- 0
G For Sale 1998 Mustang V6, Crystal White *Clean* SN95 Mustangs For Sale (1994-04) 0
Alley Oop Tips on cleaning a convertible top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
S We're really not allowed to clean the throttle body? SVT Tech Forum 2
9 Trying to clean the MAF but need that special tool? ($10 security Torx) 1996 - 2004 SN95 Mustang -General/Talk- 3
G Paint and Body Spring is finally here and got the car cleaned up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
IIGood Cleaned my 2003 GT's engine compartment Mustang Sound & Shine All 2
Jesse36 For Sale A set of2009 gt500 wheels no tires. Decent shape, they clean up ok. Wheels Tires Brakes 0
N 2014 V-6: When to clean throttle boby? 2010 - 2014 Specific Tech 4
Abbotsfordbcfoxbody Clean Low Miles Foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
A Cleaning Fuel System. 1996 - 2004 SN95 Mustang -General/Talk- 5
D Expired 1993 Mustang Gt Low Mileage Fox Body Mustangs For Sale (1979-93) 0
Nutty 5.o SOLD 1990 Mustang Lx 5.0 W/5 Speed Hatch Very Nice/clean Dark Titanium In Pa Fox Body Mustangs For Sale (1979-93) 11
drw4338 SOLD 93 Lx 5.0 Convertible (super Clean) Fox Body Mustangs For Sale (1979-93) 6
N First Post+help The Newbie With Engine Cleaning! 2005 - 2014 S-197 Mustang -General/Talk- 1
old_blue All Cleaned Up... I Think I Keep It Around 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
A Expired 1990 Ford Mustang Lx 5.0/5 Speed/145k/maryland/$7500 Obo/clean & Title In Hand. Fox Body Mustangs For Sale (1979-93) 0
S Expired Clean Supercharged Red 06 Gt, Dallas, Tx, 45k Miles S197 Mustangs For Sale (2005-14) 0
M '91 Mustang - Lower Radiator Hose Burst Driving Up Steep Hills 2.3L (N/A & Turbo) Tech 4
M Detonation After Tfi And Egr Cleaning Fox 5.0 Mustang Tech 22
D Expired 1992 Hatchback Really Clean Fox Body Mustangs For Sale (1979-93) 1
C Expired Super Clean 1999 Mustang Gt SN95 Mustangs For Sale (1994-04) 1
MikeH686 Polished Wheel Cleaning 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Mstng93SSP Anyone Use Turtle Wax Rubbing Compound To Clean Off Lucas Oil Octane Boost? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
93lx5.0 SOLD 2007 Shelby Gt500, Red W/black Stripes, $28k, 31k Miles, Very Clean S197 Mustangs For Sale (2005-14) 2
C Car Cranks But Wont Start After Maf Sensor Cleaning - Please Help. 1996 - 2004 SN95 Mustang -General/Talk- 0
