Cranks, No Start Until Jumped
Xkuzme1
50
15
18
45
Kansas City, MO
Hey y’all.
Weird thing today. Went to start and it cranked just fine, fast and normal but didn’t start.
I put an ignition test light on the coil wire and there was no spark. I looked around and the easy stuff but no obviously winner why. (Shorts, changed ignition wire, distributor cap).
I connected it up to my trickle charger because I cranked on it quite a bit. After about 2-3 mins I figured I’d try one more time. This time it fired right up.
Easy to say that it was the battery, but it was cranking just fine before. I could tell no difference.
So here is my question:
Is there some electronic part that is very picky with a very slight lack of voltage? Or is there an ignition component that becomes very voltage sensitive before a permanent failure?
Thanks,
x
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,289
5,586
193
polk county florida
Not really, have your battery tested (even if it's fairly new) along with your alternator, check cables for corrosion and loose connections.
Any recent modifications/repair?
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,436
2,869
234
74
Dublin GA
lowendmac.com
It’s Decision Tree time:
No spark = go to step #1 & 2.
Good spark - what is a good spark can be a subjective judgment. If you have any doubts, borrow a known good coil from another pre 1996 Ford.
If you do have good spark = go to step # 3
Engine fires off and then dies = go to step # 4
Make sure that you have fuel pressure when the engine fires off. Leave the fuel pressure gauge connected while testing so that you can observe what the fuel pressure is doing.
Fuel pressure OK while cranking
Go to step # 5
Be sure to use a noid light to see if the injectors are pulsing. Use the most accessible fuel injector connector for the noid test.
Noid light pulses and fuel pressure is good.
Go to step #6
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Xkuzme1
50
15
18
45
Kansas City, MO
Update:
I’ve been driving around my car with no SPOUT chip in for a couple weeks. No issues other than obvious destination because of the lack of timing advance.
The reason it would crank and no start was because the ignition capacitor in my computer was corroded. I had changed the coil, the distributor, the plug wires and nothing worked for more than a short while. I removed the spout chip and it started and ran immediately.
I ordered an A9L computer from NAPA. I took my computer out and swapped it. With the spout chip back in, it started right up. I rolled it out in the driveway to let the new computer adjust to the timing and idle air setting. I didn’t have time to drive it yesterday, but I assume that all will be good.
Thanks for all of y’all’s help.
x
Thread starter Similar threads Forum Replies Date
8 Crank no start after warm up Fox 5.0 Mustang Tech 3
A Engine Cranking but starting Fox 5.0 Mustang Tech 3
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
D 2001 Mustang GT will crank but not start SN95 4.6L Mustang Tech 3
D 93 2.3 crank but no fire 2.3L (N/A & Turbo) Tech 18
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
C 2016 Mustang V6 will crank but not start 2015+ Specific Tech 2
T Cranks but wont start 2.3L (N/A & Turbo) Tech 4
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 11
D 95 mustang 5.0 no crank no start, went thru checklist.. 1994 - 1995 Specific Tech 1
Cameron96 Engine Fox engine swap - cranks, fuel, spark and no start! Fox 5.0 Mustang Tech 3
M 1985 Mercury Capri 302 5.0L cranks but wont start Fox 5.0 Mustang Tech 2
S 72 electrical problems (click no crank) Classic Mustang Specific Tech 1
M CCRM, PCM, or something else? SN95 V6 Mustang Tech 25
P 2003 mustang GT cranks but doesnt start 1996 - 2004 SN95 Mustang -General/Talk- 3
W 1998 v6 3.8l mustang cranks but will not start 1996 - 2004 SN95 Mustang -General/Talk- 4
B Crank no start 99 4.6 . Gets fuel, obd read p0606 not sure to replace pcm SN95 4.6L Mustang Tech 1
B Engine Crank no start 99 gt 4.6l supercharged. Advice needed SN95 4.6L Mustang Tech 5
B Coolant eruption... car cranks but won’t start... HELP please! SN95 V6 Mustang Tech 5
derek2079 My 67 Stang cranks a while before starting 1965 - 1973 Classic Mustangs -General/Talk- 2
G Sn95 won’t start SN95 4.6L Mustang Tech 2
G Need help with sn95! 1996 - 2004 SN95 Mustang -General/Talk- 1
G 96 GT cranking but won’t start SN95 4.6L Mustang Tech 1
M 2016 EcoBoost dead crank, no start 2015+ Specific Tech 1
D Won’t crank single click 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
G Electrical 91 5.0 swap crank no start Fox 5.0 Mustang Tech 6
D 2000 Mustang V6 cranks, no start, and no fuel pressure (BUT has started intermittently) SN95 V6 Mustang Tech 3
T 2008 V6 Mustang - Cranking but no start on occasion - When engine is warm??? 2005 - 2014 S-197 Mustang -General/Talk- 2
S 2006 Mustang Cranks but won't start- 2005 - 2009 Specific Tech 2
starstruck106 Car overheated and now it won't turn over - help PLEASE 1994 - 1995 Specific Tech 51
R 01 gt motor swap to 00 gt roller crank no start 1996 - 2004 SN95 Mustang -General/Talk- 2
M 06' Cranks but won't start 2005 - 2014 Specific V6 Tech 3
8 Engine 93 5.0 cranks, wont start. Fox 5.0 Mustang Tech 7
C 2001 mustang v6 no crank, no start, fixed it The Welcome Wagon 1
69shocktower Electrical Will start, then it wont, crank but no fire, eliminator chip Fox 5.0 Mustang Tech 10
S No crank no start SN95 V6 Mustang Tech 5
allutz Cold start extended crank issue SN95 4.6L Mustang Tech 12
G I need a miracle! - Father's Day Gift Won't Start Fox 5.0 Mustang Tech 22
T PCM Help! No OBD2 communication, cranks but no start. 1996 - 2004 SN95 Mustang -General/Talk- 1
R Electrical Engine Swap HELP SN95 4.6L Mustang Tech 1
T 89 2.3 n/a cranks, no start 2.3L (N/A & Turbo) Tech 0
1 Car cranks but doesn't start. Used checklist, have fuel, spark, compression and timing Fox 5.0 Mustang Tech 1
R 2000 4.6 Mustang with crank no start 1996 - 2004 SN95 Mustang -General/Talk- 15
A Engine Crank, no start on cold start. Fox 5.0 Mustang Tech 19
T Electrical Cranks OK, but No Start 92 Mustang 5.0 Coil Fat Blue Spark per jrichker Fox 5.0 Mustang Tech 2
R No crank, No Start condition on 96 Mustang GT 8 CYL 4.6L Manual Trans SN95 4.6L Mustang Tech 5
R Electrical Cranks ok but no start help Fox 5.0 Mustang Tech 6
B Can someone please tell me what security system is installed on my 95 mustang 3.8. VIN: 1FALP4041SF249366 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
R 2005 crank but wont start! have fuel and spark 2005 - 2014 S-197 Mustang -General/Talk- 1
F Cranks Ok No start 90 Gt Fox 5.0 Mustang Tech 1
