Cranks Ok No start 90 Gt
Foxstang31
87
21
18
23
Recently changed my plugs cap and rotor and wires, ran perfectly for about a week. Yesterday all of the sudden it started running like crap in the way home no power/hesitation/ bogged down under any given throttle. I went through Jrinker’s no start checklist I’m getting 12v at injector, at coil, I’m getting spark at plugs and it’s building fuel pressure(pressed little valve behind alternator and fuel squirted out). Any ideas? I’m getting codes 85 51 53 54 96. These are new because I just ran codes last week
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
16,945
5,417
193
polk county florida
Just pressing the schrader valve shows you have fuel pressure, not how much, 2 or 3 lbs can squirt fuel out, get a gauge, you can rent one.
Thread starter Similar threads Forum Replies Date
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
D 2001 Mustang GT will crank but not start SN95 4.6L Mustang Tech 3
D 93 2.3 crank but no fire 2.3L (N/A & Turbo) Tech 18
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
C 2016 Mustang V6 will crank but not start 2015+ Specific Tech 2
T Cranks but wont start 2.3L (N/A & Turbo) Tech 4
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 9
D 95 mustang 5.0 no crank no start, went thru checklist.. 1994 - 1995 Specific Tech 1
Cameron96 Engine Fox engine swap - cranks, fuel, spark and no start! Fox 5.0 Mustang Tech 3
M 1985 Mercury Capri 302 5.0L cranks but wont start Fox 5.0 Mustang Tech 2
S 72 electrical problems (click no crank) Classic Mustang Specific Tech 1
M CCRM, PCM, or something else? SN95 V6 Mustang Tech 25
P 2003 mustang GT cranks but doesnt start 1996 - 2004 SN95 Mustang -General/Talk- 3
W 1998 v6 3.8l mustang cranks but will not start 1996 - 2004 SN95 Mustang -General/Talk- 4
B Crank no start 99 4.6 . Gets fuel, obd read p0606 not sure to replace pcm SN95 4.6L Mustang Tech 1
B Engine Crank no start 99 gt 4.6l supercharged. Advice needed SN95 4.6L Mustang Tech 5
B Coolant eruption... car cranks but won’t start... HELP please! SN95 V6 Mustang Tech 5
derek2079 My 67 Stang cranks a while before starting 1965 - 1973 Classic Mustangs -General/Talk- 2
G Sn95 won’t start SN95 4.6L Mustang Tech 2
G Need help with sn95! 1996 - 2004 SN95 Mustang -General/Talk- 1
G 96 GT cranking but won’t start SN95 4.6L Mustang Tech 1
Xkuzme1 Cranks, No Start Until Jumped Fox 5.0 Mustang Tech 3
M 2016 EcoBoost dead crank, no start 2015+ Specific Tech 1
D Won’t crank single click 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
G Electrical 91 5.0 swap crank no start Fox 5.0 Mustang Tech 6
D 2000 Mustang V6 cranks, no start, and no fuel pressure (BUT has started intermittently) SN95 V6 Mustang Tech 3
T 2008 V6 Mustang - Cranking but no start on occasion - When engine is warm??? 2005 - 2014 S-197 Mustang -General/Talk- 2
S 2006 Mustang Cranks but won't start- 2005 - 2009 Specific Tech 2
starstruck106 Car overheated and now it won't turn over - help PLEASE 1994 - 1995 Specific Tech 51
R 01 gt motor swap to 00 gt roller crank no start 1996 - 2004 SN95 Mustang -General/Talk- 2
M 06' Cranks but won't start 2005 - 2014 Specific V6 Tech 3
8 Engine 93 5.0 cranks, wont start. Fox 5.0 Mustang Tech 7
C 2001 mustang v6 no crank, no start, fixed it The Welcome Wagon 1
69shocktower Electrical Will start, then it wont, crank but no fire, eliminator chip Fox 5.0 Mustang Tech 10
S No crank no start SN95 V6 Mustang Tech 5
allutz Cold start extended crank issue SN95 4.6L Mustang Tech 12
G I need a miracle! - Father's Day Gift Won't Start Fox 5.0 Mustang Tech 22
T PCM Help! No OBD2 communication, cranks but no start. 1996 - 2004 SN95 Mustang -General/Talk- 1
R Electrical Engine Swap HELP SN95 4.6L Mustang Tech 1
T 89 2.3 n/a cranks, no start 2.3L (N/A & Turbo) Tech 0
1 Car cranks but doesn't start. Used checklist, have fuel, spark, compression and timing Fox 5.0 Mustang Tech 1
R 2000 4.6 Mustang with crank no start 1996 - 2004 SN95 Mustang -General/Talk- 15
A Engine Crank, no start on cold start. Fox 5.0 Mustang Tech 19
T Electrical Cranks OK, but No Start 92 Mustang 5.0 Coil Fat Blue Spark per jrichker Fox 5.0 Mustang Tech 2
R No crank, No Start condition on 96 Mustang GT 8 CYL 4.6L Manual Trans SN95 4.6L Mustang Tech 5
R Electrical Cranks ok but no start help Fox 5.0 Mustang Tech 6
B Can someone please tell me what security system is installed on my 95 mustang 3.8. VIN: 1FALP4041SF249366 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
R 2005 crank but wont start! have fuel and spark 2005 - 2014 S-197 Mustang -General/Talk- 1
H 94 Mustang - Cranks but no start SN95 V6 Mustang Tech 2
9 Engine 1990 5.0 manual crank/no start Fox 5.0 Mustang Tech 11
