Cube under dash
jack bick
9
ky.
I found a cube under the steering wheel,close to the fuse box on 87 Foxbody, had plug with 7 wires attached,motorcraft # faded out,7C9B under pt #,had 7 wires in plug,2 red w yellow stripe,in same lug, 2 blue,under same lug,2 white w pink stripe,under same lug,and 1 black under a lug by itself,anyone know whatthis does?
  • Sponsors(?)
jack bick
9
ky.
On 87 mustang,What is the elec.device located between gear-shift lever and dashboard,mounted on top of the tunnel. It is sort-of hex-shaped,got 2 small wiring harness conn.,weighs about 1 pound,with some cooling fins visable.It measures about 4 1/2" x 6",would anybody know? thanks
jack bick
9
ky.
Thanks,is it hex shaped,about 1 1/2" thick,weigh about 1 lb.,with 2 elec.connectors? It does bolt to the top of the tunnel,about 12" in front of the gearshift.
